Don't know if this has been discussed before, but leave it to me to be redundant if it has. Anyway, as we are preparing for our first outing to escape the snow, I dutifully began checking the tire pressures only to have one valve decide to let more air out than I could put in. I quickly put the cap back on and ran to an auto parts store and bought a tire valve extraction tool. A couple of turns with it and all was well. Something to be aware of, I guess. The little valve in the stem had worked itself loose is all. I now have a new tool to take with us. Only cost $5.00 and saved a lot of potential grief!
Tom & Susan & Della
2017 320S / 2015 Tacoma TRDSport
2 ·
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Sold 2023 Tab 400
Sold 2018 T@B 320S
Good one @ScottG... I have one of these in the truck...
T@bbey Road
Appleton, WI
I'd like to know how you like it.... There is no such thing as being too high tech...
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
@Awca12a do you have a tire monitor on those valve stems?
Sold 2023 Tab 400
Sold 2018 T@B 320S
Sold 2023 Tab 400
Sold 2018 T@B 320S
Happy to sell someone the TST set I have here very fairly if they are so inclined.
I belive the TST not only alerts to pressure drop but if a rapid drop it has an algorithm to alert for that too. I am looking for the piece of mind on the 400, especially towing after dark where you might not notice a low or flat tire. Complete tire failures are largely correlated to low pressure and/or high temperatures. A single tire coming apart can do more damage to the trailer than the cost of the TST. I have had a tire failure on a small utility trailer in the dark, no damage to trailer, but I had no clue behind a Suburban.
I have friends in the trucking business that use the TST and report it has saved a tire before, so I think it is worth it. So far the TST and my very accurate digital tire guage are showing within 1-2 PSI. I always pre-trip, post-trip and every couple hours while on the road and put eyeballs on the tires and equipment. I more than once been able to see a developing tire issue, both times on a rear inside tire sidewall starting to split. My latest tool to help in inspections is an infrared non contact thermometer, pretty cool for checking tires/hubs and on TV transmission and rear axle temperature.
The thermometer should be in everyone's toolbox because you just can't tell the temperature differences by back of hand or even visually.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Oh dear... I didn't know this... It seemed like such a simple addon.. Nothing is ever simple right? Like Jenn, I think I might save and buy something else. Maybe NASA is selling some of their old command module equipment. I can check on the outside skin temp on the camper and what is the current velocity of my re-entry into the campsite.
T@bbey Road
Appleton, WI
Let me share a story with you that will reaffirm your belief in nuCAMP. Here I am with my very first trailer having decided to get a last-years model Airstream on 12/31 and be the beneficiary of triple witching hour pricing. The dealer was an outstanding sort having refused to sell me the trailer I came in for after explaining that it would have been a terrible fit but this style, which was half the price, is what I didn't know I needed. He was right.
So being the avid forum reader and aspriing boy scout, I had already tried to change a tire in preparation for a summer journey just to make sure we had the correct tools and know how. This is when we discover that Airstream wheels have pretty looking lug nuts that aren't what they seem. In order to save $22.95, they used absurdly cheap steel lugnuts and then capped them with thin aluminum caps making it appear to be an aluminum locknut but in fact was something that couldn't fit or be operated in a jack wrench without deforming or refusing to fit. Off to the forums to discover the fix is a $22.95 set of solid metal chrome lugnuts and that I needed a deep high torque socket with extension so I could hammer the socket onto each cheap lugnut with a 5# hammer to get enough bite to remove the lug nuts. An hour or so later, all the lugnuts are replaced and more than half would have been impossible to remove on the road.
So there we are heading off on our 12,000 mile summer adventure fully loaded leaving at 4am and all of the sudden the dealer installed TST detector alarm goes off telling me we have low tire pressure. Pulling off the road in the dark somewhere in NJ, I first discover that the valve seat is leaking and I didn't think ahead enough to have a valve stem tool. Fortunately we are near a Pilot and with stem tool in hand, I tighten and think we are good to go. Already knew we needed to carry a portable air compressor which clearly saved our bacon so after topping off, headed back out.
No more than 5-hours into our journey we are on the side of the road multiple times topping off this tire until finally finding a tire shop open early on a weekend. This is where we learned about the high pressure brass/rubber valve stems and we were back on the road. Enough miles of that little pressure monitor and centrifugal force, the stem leaks either slowly or just fails. They quickly gave us a new valve and we went another 7,000 miles before we had to solve the problem of the awful 1-yr old Marathon tires Airstream sourced somewhere in a 50% off rack.
Point of all this.
I'm convinced that if the CEO and head of manufacturing of each trailer manufacturer commiteed themselves to using their products, the majority of our problems wouldn't exist. nuCAMP and Airstream sell plenty of trailers with the cheap valves and eventually, the owner has to deal with them. At least with nuCAMP the lug nuts were removable, the tires serviceable and we have the holy grail of Alde.
For expenditures, buying the camper was only the beginning...
And, of course, it is nice when someone says, - this is the battery you need, etc..
In regard to the tire monitor, it sounded like a good idea. I watched videos and it was an easy install. But, I have always watched my tire pressures manually, both car and trailer. I was on the road north to Green Bay once and someone ahead was pulling a flat trailer with a big load. As I watched, his left tire started smoking and then blew out... For me, that was a quick lane change...
T@bbey Road
Appleton, WI
This is for a pack of 50 but it gives you an idea of how cheap they are.
https://www.amazon.com/TR-600-Pressure-Wheel-Valve-TR600HP/dp/B00L3SYPOK
Discount Tire quoted about $4 each for me too.
Sold 2023 Tab 400
Sold 2018 T@B 320S
