Front Tub open space
lkc001
Member Posts: 877
Hello all--I remembered seeing somewhere a few people adding some wire/metal screening or something to the back and bottom of the plastic tub to keep items from falling out of the tub. I did some searching on "tub storage" and cannot find anything. Any help pointing met in the right direction would be appreciated!
2018 Tab 400
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,1800 -
@MuttonChops--yes I did see that one. The one I was looking for had put a back & floor on the tub with some kind of metal plate that had decorative holes punched all over it for airflow. Kind of like a decorate floor register but it must come in a sheet and be able to cut it with tin-snips or something?
2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
Can't help you with the thread but for the decorative floor register that you could cut with tin snips, do a google search for perforated metal.
https://www.homedepot.com/p/M-D-Building-Products-36-in-x-36-in-Small-Hole-Aluminum-Sheet-in-Black-84327/205058566?cm_mmc=Shopping%7CG%7CBase%7CD25H%7C25-4_BUILDERS_HARDWARE%7CNA%7CPLA%7c71700000035978695%7c58700004046980559%7c92700037059910574&gclid=Cj0KCQjw4fHkBRDcARIsACV58_EpGzorPuhSBVxcuZBZx-XBSGErz6gi7QjagaOB7LuOOQkgMv71AEoaAsdfEALw_wcB&gclsrc=aw.ds
I looked at doing that initially but wanted more rigidity and air flow so ended-up using a simple 1' plastic coated wire shelf instead. Posted those photos here
https://tab-rv.vanillacommunity.com/discussion/8543/t-b400-second-propane-tank-mount
F150 Pulling 2019 T@B400 BDL1 -
I remember that thread and I believe the poster used the kind of decorative grill they put on home radiator covers. You can find it in 2x3 sheets at Home Depot, etc.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium0 -
I looked all over and can’t find pics of the perforated metal screening. This was the best I could come up with. This looks like hardware cloth rather than perforated metal sheeting.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio3 -
Well this gives me a few ideas & products to go look at Home Depot! Thanks!2018 Tab 400
I think the best material for the back wall might be ‘expanded metal’. I think I’m going to do mine for my 400 BL out of this in aluminum, but you can get it in other metals as well, i.e. stainless steel. You can order it in a number of thicknesses cut to your specific dimensions here:
https://www.metalsdepot.com/aluminum-products/aluminum-expanded-metal
Alan & Natalie McKinney, TX
nüCamp: 2019 T@B 400 Boondock Lite
Dream big... work hard... never give up.0 -
That was the search term of the hour - expanded metal. @lkc001, try this.
https://tab-rv.vanillacommunity.com/search?Search=Expanded+metal
@Sharon_is_SAM Thank you. I've been trying to find what others have used---I have one of the plastic-type tubs, not a metal tub.2018 Tab 400
The expanded metal floor is standard T@G issue on their plastic tubs.
I do not have a Tag2018 Tab 400
The TaG forum may have more info regarding using expanded metal on the plastic tubs.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Can you cut an opening through the expanded metal for the propane hose? I would be concerned that the metal might cut the hose during travel.
2020 T@B 400 BD Lite0 -
Agreed, but there is probably some sort of grommet you could fit around the edge of the hole that would eliminate this concern.NoVaGuy said:Can you cut an opening through the expanded metal for the propane hose? I would be concerned that the metal might cut the hose during travel.
I installed expanded metal under the tongue area of my former 320 T@B and fabricated a diamond plate cover and latch so I could store the sewer hose and accessories there. I used a hand grinder with a diamond blade to cut the expanded metal. You could do the same and just use a sharpie or wax pencil to create your circular area for the propane line, etc. You could also use either flexible tubing that they use to protect wiring or a piece of hose, cut it and insert it over the sharp edges of the expanded metal. That should work. 👍🏻You could simplify things too, buy some small chicken wire or similar product, fabricate a small frame out of flat aluminum stock that you can buy at Home Depot and place the screening against the flat stock aluminum and hold it in place with small sheet metal screws and small fender washers, etc. You could easily she be aluminum, depending on the thickness purchased and then sheet-metal it into place. I would recommend that you use stainless screws to eliminate any corrosive action between the aluminum and metal screws.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
