leenscottfl said:judymac I think you will be glad to have the extra length even if at a dump station.
This guy has reviewed and one testing in several options. Here is te test for the Sewer Solution
http://www.thefitrv.com/rv-tips/inside-the-rv-black-tank-testing-the-sewer-solution/
I think the key is to get a high ratio of water in it and let it soak. If possible, fill the black tank with water and drive with it for a while.
jdargis said:Simple tip for black tank cleaning, toss one or two bags of ice cubes in tank, when traveling. Generally does a fair job.
The same guy takes on the ice cube advice, too
I think unless you have an in tank rinse system, you need to know that there is more left in your tank than you realize. Probably wouldn't hurt to try the tabs, too.
judymac said:Jenn, do you ever use your shower nozzle and spray into the black tank? I know you have that back flush adapter on your hose.
No, it would take too long. I have always used my flush king. After watching the videos, I will probably make some adjustments. The Ohio Turnpike (I80) has free dump stations and I will make better use of them this year when traveling to points west. I will probably fill the blank tank with water when I know I will be cruising by them just to give the tank a chance to get extra clean. I also have an unused canister of Happy Campers, which gets rave reviews they I will probably start to use when doing bigger trips where I ill be dumping more frequently. It is biodegradable and does not use formaldehyde.
I have read, often, about the "pyramid" that can develop in your black tank when you don't get enough liquid to help dissolve the solid so I tried to make sure that I used a fair amount of water let year.
I have yet to come across a dump station without a hose.
Michelle, you can use a "wand" or a device lie a Flush King to rinse the tank or pour water into the tank. I use a Flush King. You can also use the flush king to rinse the hose. There are 2 different valves: one for the black tank and one for the grey water tank.
ChanW said:Same hose, so that draining the gray helps to rinse the hose out.
Jenn, does the Flush King include caps for each end, for storage? And how do you keep track of when to shut off the rinse water? Look into the toilet, and run out to shut off the hose?
The Flush King does not include caps. I guesstimate how much water. I have wondered how I would know if I had put touch water in!
