Dutchmen T@B Resources
ScottG
ScottG Administrator Posts: 5,693
ADMIN NOTES
Description: Miscellaneous resources for owners of Dutchmen built T@Bs. North American T@Bs were built by Dutchmen from 2004 to 2009. Like their European counterparts, Dutchmen T@Bs were equipped with surge brakes rather than the electronic brakes found on later models manufactured by Pleasant Valley/nüCamp.
Created by:
Various
Posted by: Various
Disclaimer:
 Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
  • Verna
    Verna Member Posts: 6,876
    edited January 2018
  • Verna
    edited September 2020
    Dutchman (DM) T@B Fuse between the battery and converter
    The DM T@B's do not have a fuse right at the battery like the nüCamp T@B's. This "shortstop" 30Amp fuse is screwed into the tongue. Trace the red (positive) lead from the battery and you will find it. The fuse can be found at various auto parts stores.
    Symptoms will be a fully charged battery, but the lights and other 12V accessories won't work on your T@B battery. Replace this fuse and it should work, unless there are other problems, too.
  • Michigan_Mike
    edited January 2018
    Dutchmen T@B Trailer Brake Information
    Here are a couple of PDF files that provide information about the surge and electric trailer brake systems.
    edited November 2021
    Trailer Blueprints
    ADMIN NOTES
    Description: Factory drawings for Dutchmen era T@Bs. Specific details may or may not be applicable to later model T@Bs manufactured by Pleasant Vally/nuCamp.
    Created by:
    Dutchmen Manufacturing
    Posted by: mash2
    Disclaimer:
    edited August 2025
    Dutchmen T@B Brochures
    ADMIN NOTES
    Description: Marketing brochure for older Dutchmen T@Bs, Tadas and Tags. Includes basic specs and other general information.
    Created by:
    Posted by: MuttonChops, rfuss928, Sharon_is_SAM
    https://www.roamingtimes.com/2009/08/01/tda-tada-small-travel-trailer/
    Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    Dutchmen T@B Tips
    ADMIN NOTES
    Description: Handy tips for operating Dutchmen T@B features, many of which differ from newer PV/nuCamp T@Bs. Published 2005.
    Created by:
    RetroTrailerRentals.com
    edited April 2022
    Older T@B Resources
    ADMIN NOTES
    Description: Links to additional resources and sales information for older T@B and T@DA trailers. Mostly Dutchmen era info but also includes some early Pleasant Valley/Little Guy literature.
    https://www.dutchmenowners.org/forums/f59/
    Created by: Sharon_is_SAM
    Posted by: Sharon_is_SAM
    Dutchmen T@B Maintenance Schedule
    ADMIN NOTES
    Description: Comprehensive maintenance schedule for Dutchmen T@Bs and T@DAs, as well as earlier Pleasant Valley T@Bs and T@Gs.
    Created by:
    Richard Lewis
    Posted by: ColleenD2
    Dutchmen T@B Axle Bearing Information and Source
    ADMIN NOTES
    Description: Excerpt from member posting regarding their experience sourcing replacement bearings for their Dutchmen T@B.  Link to full discussion with edits here.
    Created by: mdomb529
    Posted by: mdomb529
    Dutchmen T@B/T@DA Door Lock Repair
    ADMIN NOTES
    Description: Detailed instructions for repair of the door lock by replacing the lock barrel.  Barrel and keys purchased on eBay.
    Created by: Mouseketab
    Posted by: Mouseketab
    Dutchmen T@B Keder Rail Installation
    ADMIN NOTES
    Description: Detailed instructions for adding a Keder rail to the Dutchmen T2 and clamshell models
    Forum thread:  https://tab-rv.vanillacommunity.com/discussion/12253/adding-driver-side-keder-rail-to-dutchmen-t-b-clamshell#latest
    Dutchmen Dometic Duo-Therm Cool Cat Heat Pump Manual
    ADMIN NOTES
    Description: A combination heating and cooling unit found in TaBs 2004 - mid 2014 - replaced by the Alde.
    Created by: Dometic Corporation
    Dutchmen TaB Al-Ko Chassis Care and Maintenance
    ADMIN NOTES
    Description: Excellent Al-Ko instructions for the chassis and components.
    Created by: Al-Ko
    Posted by: Sharon_is_SAM as provided by member gderrick
    Dutchmen TaB Al-Ko Frame Rubber Bellows Replacement
    ADMIN NOTES
    Description: Instructions for replacing the rubber bellows when they develop cracks and tears.
    Dutchmen TaB Awnings
    ADMIN NOTES
    Description: Installation instructions for the original "Flower Power" Sun Canopy/awning sold by Dutchmen as a TaB accessory.  It is a copy of the Netherland's made Isabella Sun Canopy produced in the USA by National Tent & Awning in Goshen, Indiana (NLA).  High quality and durable. The second generation of this model was silver colored.
    See PDF instructions below.
    The Thermarest Archwing (second photo) came along after the Dutchmen awning.  It can be staked out for additional support.
    Created by:
    Posted by: rfuss928 and a screen grabbed shot from Pinterest with Mouseketab’s Archwing.
    T@B Electrical Problems and Solutions
    Admin Notes:  Electrical troubleshooting for Dutchman and older T@Bs.  Believed to be sourced from the original Yahoo TaB Trailer Group.
    Created by:  Presumably former Dutchman TaB owner Jerry Jones
    edited August 2022
    Dutchmen LED Tail Light Install
    Admin Notes:  Instructions for installation of replacement LED tail lights in model year 2010 and earlier DM TaBs.  Believed to be sourced from original Yahoo TaB Trailer group.
    Created by:  Unknown
    Posted by:  RFuss928 and mash2
    Dutchmen T@B Power Center Diagram
    Created by:  ?
    edited April 2024
    Dutchmen T@B Al-ko Frame
    Created by:  AL-KO B & B Limited, Queensway, Royal Leamington Spa, Warwickshire, CV31 3JP. Tel: (0926) 452828 Telex: 311371 Fax: (0926) 316626
    Posted by:  R Fuss
