Dutchmen T@B Resources
ScottG
Administrator Posts: 5,681
ADMIN NOTES
Description: Miscellaneous resources for owners of Dutchmen built T@Bs. North American T@Bs were built by Dutchmen from 2004 to 2009. Like their European counterparts, Dutchmen T@Bs were equipped with surge brakes rather than the electronic brakes found on later models manufactured by Pleasant Valley/nüCamp.
Created by: Various
Posted by: Various
Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
ADMIN NOTES
Created by: Various
Posted by: Various
Surge Brakes -- troubleshooting tips
http://www.centrevilletrailer.com/how-to/surge-brake-troubleshooting-tips/Verna, Columbus, IN
Dutchman (DM) T@B Fuse between the battery and converter
The DM T@B's do not have a fuse right at the battery like the nüCamp T@B's. This "shortstop" 30Amp fuse is screwed into the tongue. Trace the red (positive) lead from the battery and you will find it. The fuse can be found at various auto parts stores.
Symptoms will be a fully charged battery, but the lights and other 12V accessories won't work on your T@B battery. Replace this fuse and it should work, unless there are other problems, too.
Dutchmen T@B Trailer Brake Information
Here are a couple of PDF files that provide information about the surge and electric trailer brake systems.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Trailer Blueprints
----------ADMIN NOTES
Description: Factory drawings for Dutchmen era T@Bs. Specific details may or may not be applicable to later model T@Bs manufactured by Pleasant Vally/nuCamp.
Created by: Dutchmen Manufacturing
Posted by: mash2
Dutchmen T@B Brochures
Description: Marketing brochure for older Dutchmen T@Bs, Tadas and Tags. Includes basic specs and other general information.
Posted by: MuttonChops, rfuss928, Sharon_is_SAM
https://www.roamingtimes.com/2009/08/01/tda-tada-small-travel-trailer/Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------2015 T@B Max S (320)
Dutchmen T@B Tips
Description: Handy tips for operating Dutchmen T@B features, many of which differ from newer PV/nuCamp T@Bs. Published 2005.
Created by: RetroTrailerRentals.com
Posted by: MuttonChopsDisclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------
Older T@B Resources
Description: Links to additional resources and sales information for older T@B and T@DA trailers. Mostly Dutchmen era info but also includes some early Pleasant Valley/Little Guy literature.
https://www.dutchmenowners.org/forums/f59/
Created by: Sharon_is_SAM
Posted by: Sharon_is_SAMDisclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------
Dutchmen T@B Maintenance Schedule
Description: Comprehensive maintenance schedule for Dutchmen T@Bs and T@DAs, as well as earlier Pleasant Valley T@Bs and T@Gs.
Created by: Richard Lewis
Posted by: ColleenD2Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------
Dutchmen T@B Axle Bearing Information and Source
Description: Excerpt from member posting regarding their experience sourcing replacement bearings for their Dutchmen T@B. Link to full discussion with edits here.
Created by: mdomb529
Posted by: mdomb529Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
Dutchmen T@B/T@DA Door Lock Repair
Description: Detailed instructions for repair of the door lock by replacing the lock barrel. Barrel and keys purchased on eBay.
Created by: Mouseketab
Posted by: MouseketabDisclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.----------
Dutchmen T@B Keder Rail Installation
Description: Detailed instructions for adding a Keder rail to the Dutchmen T2 and clamshell models
Forum thread: https://tab-rv.vanillacommunity.com/discussion/12253/adding-driver-side-keder-rail-to-dutchmen-t-b-clamshell#latest
Dutchmen Dometic Duo-Therm Cool Cat Heat Pump Manual
Description: A combination heating and cooling unit found in TaBs 2004 - mid 2014 - replaced by the Alde.
Created by: Dometic Corporation
--------Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Dutchmen TaB Al-Ko Chassis Care and Maintenance
Description: Excellent Al-Ko instructions for the chassis and components.
Created by: Al-Ko
Posted by: Sharon_is_SAM as provided by member gderrickDisclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
Dutchmen TaB Al-Ko Frame Rubber Bellows Replacement
Description: Instructions for replacing the rubber bellows when they develop cracks and tears.
ADMIN NOTES
Dutchmen TaB Awnings
Description: Installation instructions for the original "Flower Power" Sun Canopy/awning sold by Dutchmen as a TaB accessory. It is a copy of the Netherland's made Isabella Sun Canopy produced in the USA by National Tent & Awning in Goshen, Indiana (NLA). High quality and durable. The second generation of this model was silver colored.
See PDF instructions below.
The Thermarest Archwing (second photo) came along after the Dutchmen awning. It can be staked out for additional support.
Created by: National Tent & Awning
Posted by: rfuss928 and a screen grabbed shot from Pinterest with Mouseketab’s Archwing.
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2 -
T@B Electrical Problems and Solutions
Admin Notes: Electrical troubleshooting for Dutchman and older T@Bs. Believed to be sourced from the original Yahoo TaB Trailer Group.
Created by: Presumably former Dutchman TaB owner Jerry Jones
Posted by: Sharon_is_SAMSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Dutchmen LED Tail Light Install
Admin Notes: Instructions for installation of replacement LED tail lights in model year 2010 and earlier DM TaBs. Believed to be sourced from original Yahoo TaB Trailer group.
Created by: Unknown
Posted by: RFuss928 and mash2
Dutchmen T@B Power Center Diagram
Created by: ?
Dutchmen T@B Al-ko Frame
Created by: AL-KO B & B Limited, Queensway, Royal Leamington Spa, Warwickshire, CV31 3JP. Tel: (0926) 452828 Telex: 311371 Fax: (0926) 316626
Posted by: R FussSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
- 143 Events & News
- 923 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
