I recently added this ThermPro Indoor/Outdoor Humidity &Teperature monitor to my T@B 400.
It was not real expensive... under $20 I think, but I’ve had a real tough time finding a good place for the outdoor sensor unit. I first mounted the base/monitor on the same wall and just below the Alde control panel, thinking it would be good to have it there to monitor the inside temp accuracy of both the Alde and the Dometic. I next mounted the outdoor sensor to the back of my LP tub, but found that the base station could not maintain the connection, even though the direct distance was only 6 or 7 feet. The unit I bought claimed to have a 330 foot range, diminished 50% for each wall between the base and the outdoor sensor. The batteries are fresh, so that’s not the issue. I figured maybe the diamond plating might be the problem so I brought the units together to verify I could still make a connection, then velcro’d the outside sensor to the trailer frame directly below the same wall the base was mounted on, just to the left of the entrance step. Again, after a minute or 2, the connection was lost.
So, I’m putting my puttering around on hold, and bringing the question to you all: what system and solutions have you found successful for monitoring and displaying an accurate indoor and, more importantly (to me at least), outdoor temperature/humidity from inside your nüCamp transpor
t@bles?
Alan & Natalie McKinney, TXnüCamp: 2019 T@B 400 Boondock Lite
https://www.acurite.com/multi-sensor-thermometer-with-2-indoor-sensors-and-1-outdoor-sensor.html
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
1-inside fridge
2-truck glove box
3-ARB (it is +3 * above the ARB display)
4-front tub (it’s in the shade and doesn’t get as hot there as it would outside) and it also shows the inside temp as a rolling display on #4. (79.8* currently outside at 9:30 am)
Knock on wood, it’s 3 years old and doing well.
On my 400, I have it across from the door using Command Strip Velcro. In my 320, I had it on the wooden valence above the door side (passenger side) window, above the end of that window, using the same Command Strip Velcro.
Quote from NuCamp service for part and labor was $500, that was more than I wanted to pay. It plugs directly into an existing plug on the Alde, only labor is getting it outside and mounted. I may discover that $500 was a good buy, BUT I just don't see this being that hard to DIY.
2012 Jeep Liberty KK a/k/a "Libby"
https://www.amazon.com/Ambient-Weather-WS-10-8-Channel-Thermo-Hygrometer/dp/B00FX8ZGOO/
I’ve only had trouble with the ARB, sometimes. There’s no consistency as to when it will show and when it won’t. I do believe that the thickness of the ARB walls has something g to do with it.
I also had the Alde battery backup installed and it allows you to hold your settings without the need to re-set the thermostat each time the unit is turned on and off.
I’m really not sure why or what was truly causing the interference, nor if the Alde control was compromised as well, but just cautioning other T@B owners to be wary.
