Better jack wheel?
lkc001lkc001 Member Posts: 878
edited April 2019 in Trailer & Towing
Hello all--just wondering if anyone has replaced their jack wheel with something a bit wider or a different type of rubber that is more like a tire (still only 6" diameter) so that it rolls better?  I was not happy with the way the standard wheel rolled on my concrete driveway.  The jack wheel I had on my old little popup trailer was easier to get pointed in the right direction than this one.  I was expecting this trailer to turn easily as many people here have said it does, and I did not find that to be the case--I had to work to get the wheel going into the 90 degree pivot I was making in my driveway to get it into it's spot.    I checked Harbor Freight and they didn't have anything that was 6" diameter with the hole in the short post to run the pin through.
Also--is this a 2" diameter post?
2018 Tab 400
