Several changes I see from pics of the few that have arrived on dealer lots, some changes I'v seen previously documented, some not:
1) New (presumably faster-draining) bath sink, square
2) New Avia-style 'wand' shower head, single temp-control handle
3) Outlets near dinette moved below passenger-side cushion,
looks like Dometic may now be mounted there (easier filter access?)
4) Exterior screen for Dometic A/C intake on front-left driver side is gone (and is not re-located to passenger side; perhaps
bottom intake?)
5) Kitchen sink no longer has p-trap, giving extra storage room
6) Note the new flooring in the images that show the floor; hard to see, but definitely different than before, almost with a 'macro' cross-hatched appearance
Looking at a 5/18 delivery for our BDL, can't wait!
-J
And the CoolCat must be in the same area unless they did a major interior layout redesign, which I'm sure we would have heard something about.
So where is the exhaust vent?
Inquiring minds want to know!!
I do like the look without the large vent on the side however...
So either the 3-way fridge vent has moved as well (where to?), or the 3-way fridge has been relocated (again, where to?), or the WFCO has been moved for the 2-way fridge to the same location as the 3-way?
https://www.parrisrv.com/product/new-2020-nucamp-rv-tab-400-std-dot-model-1021085-102
I didn’t notice that the WFCO had moved to under the couch area on a unit that clearly doesn’t have the three way fridge on the drivers side, but you can see it in these pictures as well.
Edit: You’ve piqued my interest. Here’s another 2020 listing:
https://www.rvt.com/Nucamp-TAB-400-2020-Chippewa-Falls-WI-ID8590949-UX128707
So, on this one, the coolcat vent is gone on the outside of the Tab! I also notice new vent holes inside under the bed, they look an awful lot like the coolcat vents. I just don’t see an outside vent, so did they move the coolcat under the bed and the exterior vent underneath the trailer?
Oddly, I see the coolcat duct on one of the 2020 Tab’s (with a 3 way fridge, it’s in the virtual tour of the parrisrv link), but I don’t see ducts on either of the Tab’s with 2 way fridges. It also seems like the Tab 400’s with the 3way fridge still have the coolcat under the drives side couch area.
2019 Toyota Tacoma TRD Off-Road
Seattle, WA
Thanks to this thread now I know what a WFCO is, not that I know where it was on previous MY's...
There is no model without A/C, or option to delete A/C, at least on the 2020 order form I got a few weeks ago.
So this is becoming quite the mystery.
I'm a little sad to see that the passenger side dinette storage is gone (with the WFCO moved there) even with the 2-way fridge - I already had plans for that space!!
1) WFCO and CoolCat locations have been swapped (for tongue weight considerations), intake for A/C is now on the underside.
2) Driver side dinette seat now becomes a hydraulic-assist storage area.
3) 'Boondock Edge' tongue platforms now being installed on 400 BDLs (see pic taken from the Edge, they don't have pics yet).
4) Lastly, and most importantly: Tongue weights have decreased substantially, nearly 40 lbs! The only question mark here is whether that number was weighed with or without the 'new' aluminum tongue platform (which is ~30 lbs). [Again don't quote me on this, but they should be releasing the info in the next week or two. Super-great news for those of us towing with 5k tow vehicles!]
I should hear back on Monday as to what was actually weighed, etc. They now have proper scales, and all new units will receive a yellow sticker with ACTUAL weights.
Cheers,
Jeff
Great info...thank you. Love the idea of the tongue platform, assuming the tongue weight isn't too heavy to use it for anything.
- Is this discussion saying the cool cat has been moved under the bed?
- If so is anyone concerned about having that thing rumbling under the bed?
- I also see there is a hydraulic-assist storage area under the driver's side seat now. What is that for and is is standard or optional?
- All in all is sounds like the 2020 has less storage space?
- Also saw a picture online that shows the rear access panel where the battery cutoff switch is but no batteries. Did they get moved also?
Thanks in advance on any info you all can provide.2018 Ford F-150 2.7L Ecoboost with tow package
PNW
We shall see...
https://tab-rv.vanillacommunity.com/discussion/8865/new-owner-2020-t-b-400-bdl-w-solar-weights-pics/
I'm not too worried about it, but we'll be off-grid most of the time,
PNW
See https://tab-rv.vanillacommunity.com/discussion/9115/2020-t-b-400-fresh-water-capacity-change#latest
My wife and I had a bunch of questions about the 2020 TAB400 before we took delivery of ours over a month ago, so we put together a walkthrough tour of ours once it arrived (and we had a couple trips under our belt). Hopefully this helps some other future or potential 2020 TAB 400 owners as well:
Seattle, WA
