Hot Water - No Hot Water
dagits
Member Posts: 10
Looking for some feedback. We just de-winterized our 2017 T@B S Max Outback. The Alde heat works fine. We opened the valves for hot water and got hot water first try. Yay! Later no hot water. Adjusted the mixer value and had hot water. Next day, no hot water. I'm not understanding the intermittent hot water. Can anyone share some possible solutions?
Following2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
@dagits, when you say you adjusted the mixer valve, did you back out the screw for the knob, or did you just turn the knob?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Just turned the knob.
Are you sure the Alde bypass valve is closed? Having that open could inadvertently "short-circuit" the HW distribution system (though I'm not sure why it would occur intermittently).
@dagits, please read this thread for your answer.
https://tab-rv.vanillacommunity.com/discussion/2676/little-hot-water/p1
ScottG, the bypass valve is closed. We learned that one last year. :-)
Sharon, thank you. I will take a look at the link. Hopefully the answer will be in there.
- 920 Introductions
- 74 Teardrop Groups & Links
