Offroading with 320 Boondock Edge
Looked at this model today and am wondering if the underbody shielding is robust enough for off-roading.
Seems kinda flimsy and bendy...
Anyone have problems with this?
  • MuttonChopsMuttonChops Member Posts: 1,756
    Frequent question.  Use the forum 'Search' function (near top of page) to find several threads on this topic.
    I'll include two links for you to get started.
    The first link includes this remark from @ScottG
    "Conventional wisdom is that except for a little extra ground clearance, the "Boondock" package is mostly about appearance and convenience. The chassis and camper body are the same as the standard T@Bs.
    That said, people certainly do take them offroad. If you search around here on the forum, I know there a few discussions on this topic, as well as some photos."
    It it surely isn’t a skid plate. I wouldn’t want to belly slide the 320 over any rock piles, that’s for sure. The FW tank and plumbing is right up under there, so....cuidado!
    @4ncar is spot on. I will add that be prepapred for your TV to break, cupboards to open and contents to spill, and screws to work their way loose (probably caulk, too.) If you are looking to travel a few rougher forest service road, the boondock will be fine. I would not take it true offloading where you would normally want skid plates, rock rails, or lockers.
    edited May 2019
    jkjenn said:
    @4ncar is spot on. I will add that be prepapred for your TV to break,....
    i have to agree with the other points, but this???  If they are asking this question, i would beleive that they have some off road knowledge, but that they si ply do not know about the boondock.
    i remember when we first stopped to look at the outback / Boondock T@G, my GF was laying on the bed, I was laying under the trailer.  Lol
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
    Let me clarify...
    I meant TV, as in television, not Tow Vehicle.
    So we just need to convince NuCamp we need the 320 Rubicon edition?
