"Conventional wisdom is that except for a little extra ground
clearance, the "Boondock" package is mostly about appearance and
convenience. The chassis and camper body are the same as the standard T@Bs.
That
said, people certainly do take them offroad. If you search around here
on the forum, I know there a few discussions on this topic, as well as
some photos."
It it surely isn’t a skid plate. I wouldn’t want to belly slide the 320 over any rock piles, that’s for sure. The FW tank and plumbing is right up under there, so....cuidado!
@4ncar is spot on. I will add that be prepapred for your TV to break, cupboards to open and contents to spill, and screws to work their way loose (probably caulk, too.) If you are looking to travel a few rougher forest service road, the boondock will be fine. I would not take it true offloading where you would normally want skid plates, rock rails, or lockers.
@4ncar is spot on. I will add that be prepapred for your TV to break,....
i have to agree with the other points, but this??? If they are asking this question, i would beleive that they have some off road knowledge, but that they si ply do not know about the boondock.
i remember when we first stopped to look at the outback / Boondock T@G, my GF was laying on the bed, I was laying under the trailer. Lol
2017 T@G Max Outback "Le Refuge" TV 2005 jeep TJ unlimited and/or 2005 Nissan X-Trail 4wd Alaskan Malamuthe on board!
I meant TV, as in television, not Tow Vehicle.
