I have never filled my fresh water tank. I always hook up to shore water supply. Does that mean my fresh tank is empty? (I did once empty it from the valve under and behind the step.) I guess I’m asking if I’m unknowingly carrying water weight on the road even if I don’t use that second fill port. And if I should routinely open that valve and drain the tank before road trips.
2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.
0 ·
The easiest way to find out if there is water in the fresh water holding tank is to open the drain valve. Be careful, because the valve drain tube points out toward the passenger side of the camper, so if the tank is full, you may get sprayed by the water. Opening that valve will reveal whether there is any (even if just a small amount) of water in the fresh water holding tank. If it continues to drain, then you likely have a full, or partially full, tank. Sounds like you will want to completely empty that tank since you have no need for that water when hooked up at a campground or at your house. If and when you do decide to use the fresh water holding tank, you will want to sanitize it first.
You fill the fresh water tank separately through the fresh water tank fill inlet on the driver's side of the camper. It is totally separate from the water supply connection that uses a hose from the campground/house supply. The water pump, which is located behind the toilet wall (the small compartment with the door behind the toilet) pumps water from the fresh water tank. The fresh water tank is your water source when you are boondocking and do not have access to a municipal/campground water connection.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Bayliss, in case I ever need the fresh water tank, how do I sanitize it? pthomas745 I have See Level. It never says anything about the fresh tank but “13.” But it’s ok, I can just open the valve to be sure it’s empty. That tank monitor is another mystery to be solved on another day. 🙄
2014 Mazda CX 5
Best to sanitize where you can hook up to sewer. To sanitize the fresh water tank, first isolate your Alde by turning the Alde bypass valve parallel with the pex, and close the valves on the hot and cold water supply. Prepare a dilute mixture of 1/4 cup of regular household chlorine bleach in a gallon of water and pour that into the fresh tank. Then fill the tank with water. Turn on the pump and open a tap until you smell bleach then close. Do that with all your taps - hot, cold, shower, outside shower, sink. Then turn off your pump and let it sit for a few hours. Then, turn on your pump and open all your taps and empty your fresh water tank. If hooked up to the sewer, I would open the gray tank valve so you don’t overflow into your shower. After your tank is empty and the taps are sputtering, close your taps, fill your fresh tank with water and then open your taps and flush again. Do this until no further bleach odor. After there is no further odor of bleach, close the Alde bypass valve and open the hot and cold water supply valves so you can let water into the Alde tank and camp on! Close your gray tank valve, too.
(Check our your valve arrangement in the Alde Manual. To sanitize and protect your Alde from bleach, put your valves into the position for winterization. Don’t forget to put them back into camping mode after sanitizing.)
All the more reason to sanitize the fresh system each year like @Sharon_is_SAM describes.
Sanitize fresh water tank
2014 Mazda CX 5
https://tab-rv.vanillacommunity.com/discussion/8904/de-winterizing-and-sanitizing#latest
