My step is showing signs of wear and some sag and I plan to replace it this spring. Due to ourseemingky ongoing wet weather combined with my massive springtime allergy attack, I have been unable to crawl underneath to see if it is a simple replacement. Has anyone done it? I am thinking it make sense to find one that drops a couple if extra inches (I have the boo dock axle) but I am not sure if that would just make the step from the step to the trailer more awkward. Any thoughts?
1 ·
Thanks, but the last thing I need is one more thing to pack!
And dimensions of the mounting holes? (@bayliss, Frustrating!)
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
2013 Tundra TRD 5.7L
Massachusetts
https://www.etrailer.com/RV-and-Camper-Steps/Hickory-RV-Steps/951243EXTALC1.html
The guys at etrailer are pretty responsive, and you might be able to get the bolt pattern details from them.
7 7/8” wide
20 1/2” long
And I do not know how to measure for the bolt pattern. That may be a question for tech@nucamprv.com.
If you need different photos, tell what you need to see.
The first photo is looking up at the step from the front of the step.
From front of step, looking down the passenger side at my folded chairs
Looking downward at the step
3/4” plywood cut 15”x 22 1/2” bolted to existing step. Because of the added lever you should use
Quick Products
$10.17
The one I used required some cutting and welding to make it short enough.
Camco
$17.56
