Renogy Solar Briefcase to Zamp connector
Renogy makes a Mc4 to sae adaptor cable
 https://www.amazon.com/Renogy-MC4-to-SAE-Adaptor/dp/B01N1TALFY/ref=sr_1_4?keywords=MC4+to+SAE+Adapter+12+AWG+Cable&qid=1558658235&s=gateway&sr=8-4
I believe this will work to connect my Renogy panel to the zamp connector as long as I reverse the leads coming from the zamp connector to the battey. I am also ordering a 20 foot extender cable.  Am I correct?
Mickey & Terri
2016 Max S
Kalamazoo Michigan
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,528
    Correct.  Zamp requires a reversed polarity, so just reverse the solar port leads at the battery and use the adapter.  Simple fix.  Make sure to order 10 gauge extensions to prevent voltage drop.
    ScottGScottG Administrator Posts: 5,477
    SOAPBOX WARNING...
    Whatever you decide to do, confirm your runs and connections either visually or with a multimeter that tests continuity. That darn Zamp "reverse polarity" thing has generated so much confusion here that I would trust nothing but my own eyes. Just make sure positives are always connected to positives and negatives are always connected to negatives and all will be well!
    CbusguyCbusguy Member Posts: 771
    Zamp didn't do anyone any favors with their financially driven decision.   Personally I would remove it and install something else.
    2009 GMC Canyon,   3.7 liter
    @mandt, we also removed the Zamp sticker after we reversed the leads at the terminal.
    mgreen2mgreen2 Member Posts: 88
    one advantage of the Zamp plug is that the positive wire is enclosed so its less likely you touch a positive wire to metal and create a spark, short etc. I used the renogy adapter for this reason. When you have the solar panel exposed to the sun its creating juice immediately. If you touch positive to metal and create a short you can damage the battery.
    TerryV6TerryV6 Member Posts: 1,092
    From advice from others here, we went with the tecmate optimate polarity adapter. It was the easiest for a non electrical techie like me.
    Terry & Jody...  2016 Dodge Ram 1500
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
