T@B 400 front window leak
Todd77
Todd77 Member Posts: 34
Has anyone out there had issues with their front window leaking?
  • jgram2
    jgram2 Member Posts: 1,522
    For clarity, what year/model T@B do you have?
  • Todd77
    I think it is a 2018 400.  It is possible that it is a 2017, but not sure.  I got it almost a year ago.
    The 400 started with the 2018 model.
  • jgram2
    @Todd77 We’ve had posts about the star-gazer ’s window leaking, but not the front window. Perhaps you could call your dealer and ask about potential repair costs? There are a few posts about leaks that might give you some things to look for-searched on window leaks, https://tab-rv.vanillacommunity.com/discussion/comment/82396#Comment_82396 , https://tab-rv.vanillacommunity.com/discussion/4074/side-window-leaks
  • Todd77
    Okay, thanks!  Yeah, both have leaked at different times for different reasons.  The star gazer window leaked before I got it off the lot.  They washed it for me to take it home, and apparently the pressure washer caused the issue.  The front window is leaking under constant rain, like what I am experiencing in Seward AK currently.
  • @Todd77 Could you post what you found out about the cause/solution of the front window leak. Our 2018 T@B400 has water entering at the bottom of each side of the front window. ( approx location indicated by blue tape in pic) despite firmly latching window. Has anyone else experienced this problem or have any suggestions?
    Pam and John
    Champlin, Minnesota
    2018 T@B400 and a 2025 Ridgeline Trailsport
