T@B 400 front window leak
Todd77
Member Posts: 34
Has anyone out there had issues with their front window leaking?
For clarity, what year/model T@B do you have?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
I think it is a 2018 400. It is possible that it is a 2017, but not sure. I got it almost a year ago.
The 400 started with the 2018 model.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Todd77 We’ve had posts about the star-gazer ’s window leaking, but not the front window. Perhaps you could call your dealer and ask about potential repair costs? There are a few posts about leaks that might give you some things to look for-searched on window leaks, https://tab-rv.vanillacommunity.com/discussion/comment/82396#Comment_82396 , https://tab-rv.vanillacommunity.com/discussion/4074/side-window-leaksJohn, Judi, Guinness & OD in PDX
Okay, thanks! Yeah, both have leaked at different times for different reasons. The star gazer window leaked before I got it off the lot. They washed it for me to take it home, and apparently the pressure washer caused the issue. The front window is leaking under constant rain, like what I am experiencing in Seward AK currently.
@Todd77 Could you post what you found out about the cause/solution of the front window leak. Our 2018 T@B400 has water entering at the bottom of each side of the front window. ( approx location indicated by blue tape in pic) despite firmly latching window. Has anyone else experienced this problem or have any suggestions?
Pam and JohnChamplin, Minnesota2018 T@B400 and a 2025 Ridgeline Trailsport
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
