I just finished installing a small pure sine
wave inverter in our 2018 320S Boondock, and thought I’d share some photos and rationale in the hope it’s useful to others.
The inverter I chose is the 300W Samlex Solar
PST-300-12 PST Series Pure Sine Wave Inverter. My wife is a photographer and
the inverter will be used to charge camera batteries and to charge/power her high-end
graphics laptop (for which a DC-DC adapter with enough wattage is not
available).
I installed the inverter in
the driver’s side under-bench area - but instead of building a mounting platform
around the wheel well as others have done, I built a platform on the inboard
wall, behind the LP/CO detector.
For
the AC wiring I moved the existing GFCI outlet receptacle to a new electrical
box inside the bench area, then reconnected it to the WFCO and to
the other AC outlets exactly as before. Then I installed a second outlet receptacle
in the original box, but instead of wiring it with romex I used a 14/3 power
tool cord (black plug in photo) which we can plug either into the GFCI
outlet when we’re on shore power, or into the inverter when we’re boondocking. This gives us a dual-purpose outlet but without any risk of any cross-circuiting. On shore
power, all outlets are still GFCI protected. When boondocking, only the bench
outlet will be powered (and GFCI-protected) by the inverter, which is really
all we need.
(ignore the blue switch in upper right above - part of a different project)
We’re
stingy with our 12V usage and don’t plan on drawing more than 130W from the
inverter, so for the DC input I just tapped into the existing battery wiring
going to the WFCO (using a heavy-duty splicer for the +12V wire) . Our Victron battery
monitor shows that under normal/expected loads we’re still well under the 30A max
for that circuit, but I will continue to test and check. If amperage limits or
voltage drop turns out to be an issue, I’ll consider running dedicated wires to
the battery.
As with
any T@B mod, it took a while to figure out how to shoehorn everything in, but I’m
happy with the result so far. Shakedown cruise is next weekend.
I wonder if you could hardwire a toggle switch to flip between the two power sources instead of re-plugging each time. Also wondering if you will ever forget to switch it back to AC, since it would still work on DC when not needed, just wasting energy.
https://smile.amazon.com/gp/product/B004S5Y158/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I had decided early on that a transfer switch would be overkill (and also too pricey) for this very basic setup, and since our expected usage involves only infrequent switch-overs, I’m not worried at all about wear on the plug or cord.
Also not too worried about forgetting to switch back to shore power AC when available, since we’re always pretty hyper-aware of our electrical situation (plus the inverter will be turned off by default).
I could have upgraded to the 600W Samlex, which includes a port for a remote on/off switch, but again decided it would be overkill and more $$$.
I'd certainly rather run separate cables, I'll have to go take a look at running wires underneath and see if I can keep them out of the way.
https://www.batterystuff.com/kb/tools/dc-to-ac-amperage-conversion-run-through-an-inverter.html
One would need 4 AWG cable or better to handle this kind of current.
Power (watts) = voltage (volts) * current (amperes)
That seems like a heck of alot of amps to pull out of the battery. Tho I suppose its only for short times and I'll not even be using all 1000 watts.
What are you typical AGM batteries going to like for max discharge rates?
Here is a photo, inverter in on the partition at the bottom, fuses are to the left of the inverter:
Agm battery's do not like high amp draws and the
inverters maybe a contributing factor to the premature demise of so many tab 400 battery's.
