I was wondering if anyone has opted out of having the propane stove and use an induction plate instead? My husband and I plan on purchasing the T@B 400 in the 2020 season and we are having tons of discussions. I would like to have no stove on the counter and use the induction plate to cook. What are people's thoughts on this?
0 ·
So, when trying to sell a 400 in a few years, the absence of the propane stove would definitely limit your buying audience.
The propane stove does have a sturdy glass top so you could just place your induction top on the glass for cooking, and just leave the propane stove where it is.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
If I get rid of the Tab it would be for the new Avia in a few years, only because full timing in a Tab may be limiting for use, although I know some do it.
As for as the OP, I highly recommend ditching the idea of a Tab minus the cooktop, if for no other reason weird mods are usually a killer on resale. The practical side isn't good either unless like mentioned you only camp with 30a shore service or lug a generator everyplace. Off grid could be done for limited use AFTER adding a 2000w or bigger inverter, but doesn't seem very practical.
1. Hard to power an induction cooktop without hookups or a generator
2. Bad for resale value
if you want to use an induction burner and you’re worried about breaking the glass cooktop cover you can have a piece of StarBoard (https://www.tapplastics.com/product/plastics/cut_to_size_plastic/king_starboard/526) or some other material cut to an appropriate size/shape to put over the glass.
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
MOUSE-KE-T@B
Harvest, AL
Tampa FL
North Texas - Retired Air Force
Trips - 47 Mileage - 58,853
On removing the cooktop, if you actually removed it from the countertop you'll have to build something to fill the hole or up the mod to a new countertop. Seems like less work to just find a piece of cutting board material (or buy a large cutting board) and put rubber feet under it to lift it up to clear the stove. Make sure to secure it for travel because things will fly around and that one would be a pretty heavy projectile.
We carry a 2 burner camp stove and cook outside and we also have a one burner induction unit we enjoy.
There is always an electric water kettle. We augment the propane stove with a Dutch oven, toaster oven, or electric skillet. Sometimes the Coleman Road Trip grill comes with us. It all depends on the menu for the trip. I built a wood cover for the stove (2018) and put the electric appliance on top of the cover. Keeping the stove allows you to go backwards. Mods should never reduce usability.
"Just Enough"
