TV Antenna
Hello Folks,
We picked up the new 320 S last week. I was wondering what type of TV antenna the group suggest. We are planning our maiden voyage for June 13th and will be heading to Allegany State Park in NY. I was considering a TV Antenna from Amazon. Would appreciate the advice.
Thanks,
Keith Stamper
TAB 320 S Boondock Edge
TV 2016 Honda Pilot AWD
  • NinabeanNinabean Member Posts: 68
    Hello Rerail.
    This is what I use along with accessories to use the iPhone and iPad to watch downloaded movies and tv shows.  Works great!
    Follow You Tubber Travels with Delaney for a video on this.
    2019 T@b 400 “Hazel”   Towed with a 2013 Ford F-150 STX  4X4 SuperCab 5.0L
    table mod
    Hi Keith. Well, remember you need something with height. When it comes to any antenna, physics still reigns. You need height (or a sophisticated dish that points at a very high antenna satellite lol). There are people that just put an antenna on the top of the T@B when in an area that has easy access to HDTV channels. Another friend of mine has a pole with the antenna at the top. I like to compare what they get to what the little toy hauler gets on it's powered antenna. It's usually about the same (my little toy hauler roof is fairly high).
  • MouseketabMouseketab Member Posts: 1,238
    I got the Wineguard Hideaway antenna https://www.sportsmansguide.com/product/index/winegard-hideaway-hdtv-rv-antenna?a=688749 Unfortunately, it seems to be discontinued, but I mounted it to a 6 ft piece of electrical conduit instead of the side of my trailer. I then also bring a 2 ft piece of rebar and pound it into the ground in a good location, and slide the pole over the top of the rebar. Then I run a piece of coax from the outlet on the trailer to the antenna. (I carry 50 ft.) When I know I'll have cable at the campground, I can leave the antenna at home. It just lays on the floor of the T@B for travel.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
