![[Deleted User]](https://tab-rv.vanillacommunity.com/applications/dashboard/design/images/defaulticon.png) [Deleted User]
[Deleted User]
            My problem is the round a/c vent in the back bed area is so low down it blows directly on my head and face. Its unbearable. I've resorted to blocking the vent with a pillow but that's not working very well. I've also tried turning it every possible way and it simply blows on my head from a different angle after bouncing down off the sloped ceiling. It's a problem even with the vent fan on low. It still blows very hard.  I realize the large fridge is the reason the vent is so low.  I was also trying to find a vent where the lovers can be partially closed but I haven't found anything yet that looks like it will work and/or fit.
Is this bothering anyone else? Have you come up with a solution?
Thanks
2019 T@B 400 Boondock
I think this might work. I just ordered it on Amazon. I didn't post the link because I think we are not supposed to post links in the forum.
Valterra 1221.1409 A10-3351VP Rotating/Dampered Heating and A/C Register-4" ID x 5-3/8" OD, Light Brown
Sorry about the big font, it won't let me fix it!
The vent I ordered did not work. It fit, it looked good, and it closed but it left an opening around the outer edges and allowed almost as much air to pass through as with it open, and it whistled when fully closed. I may just try some tape over part of the vent. It that fails then I will sleep at the other end. It seems like such an obvious design flaw to me. I can't imagine anyone can really stand to have that much air blowing on their head and face when sleeping.
I'm still waiting for NuCamp to respond through my dealer to find out if there are any other potential areas where the duct could be re-routed. Would be a major task though to move it and have to cut a new hole.
It seems you ought to be able to remove the vent and place a piece of tin foil inside and remount. I would think that might completely block the air flow if done correctly. I know that is more of a ‘permanent’ fix and you might wish you had the air back there in the daytime, but it might solve your evening woes. If temps aren’t too high I’m guessing you could compensate with a slightly lower thermostat setting at night to allow the other 2 vents to handle the cooling load for the entire trailer.
nüCamp: 2019 T@B 400 Boondock Lite
Chili, NY
Can you not adjust the air veins on the vents to redirect the flow? I've rotated all three of mine so they direct the air upwards.
San Diego, CA
www.airbossone.com
I opted to install a 4" duct damper behind the drawer below the fridge. The damper probably cuts up to ¾ of the air flow making sleeping less of an icebox experience. A link to the damper at Home Depot is in my post above.
2008 Toyota Sequoia 5.7 L
Did you get the powered damper? And, does it whistle loud when its closed? I bought a replacement plastic vent that had a built in damper but it whistled so loud I couldnt use it.
I'd love to know how you address this...I guess we all have our crosses to bear...the Air8 folks complain of not enough cooling and the the CoolCat folks complain of too much!
I'm wondering though if that extra air pressure now coming out the front vents isn't going to make the thermostat be even more wonky?
I just took the panel off below the fridge and the drawer to see what's behind there, and I'm thinking about putting in a splitter and splitting off to another duct to come out that front panel close to the floor. I would have to make a new 4" hole on the front there, but that shouldn't be a problem. I'm thinking then, it would cut back on the air flow in my face, but not push that additional air to the front. Then I would have two vents in the back area.
Maybe this black one also with a damper is an option too: http://www.rvlocksandmore.com/B-B-Molders/Grills-Vents-Registers/CP-TVD-BLK_2
