Closet Upgrade :)
nickitheforester
Member Posts: 5
We added two shelves to take full advantage of the storage capacity in the closet of our T@B 400. Just by adding furring strips and plywood shelving, we added 2-3 useable shelf spaces in addition to the bungee storage cubbies and hanger area. Cheers!
3
Shelfboard is near perfect, if not a perfect match! Did you order from nucamp?TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
This is where I as a 320 S owner turn just a teeny bit green with envy.. what is this "closet" of which you speak ..
~Tananda
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
I'm New to nuCamp and TearDrops but have owned a Class A in the past0 -
That's where you store all the stuff you don't really need. ;-)Seriously, I'm a little envious myself. Nice shelves! I'm also little surprised it didn't come with shelves--I assume it's designed for hanging clothes from a bar?And is that a heating vent inside the closet?!!2015 T@B Max S (320)
Nope. That is the glycol expansion tank. It's in the closet on 400s with the smaller refrigerator. It's to the right of the driver's side porthole window on 400s with the 3-way fridge. And yes, the reason for no shelves in the closet standard from the factory is that the closet is set up to accommodate longer clothing, like coats.ScottG said:That's where you store all the stuff you don't really need. ;-)Seriously, I'm a little envious myself. Nice shelves! I'm also little surprised it didn't come with shelves--I assume it's designed for hanging clothes from a bar?And is that a heating vent inside the closet?!!2019 T@B 400 Boondock Lite
2019 Chevy Colorado Z71 Duramax1 -
Thanks, JEB--I know the 400 is pretty posh but heated clothes seemed just a little over the top! :-)
~Tananda
I'm New to nuCamp and TearDrops but have owned a Class A in the past2 -
My low-tech version... Yours looks nicer, but the advantage to my cheapie version is that I can still hang a thing or two if need be. (I hope the picture is sized correctly. I tried, but I really don't know what I'm doing!)
Edited for sizing. Sharon
2 -
I like your use of hanging shelves. Very easily removed when you need to access the glycol reservoir.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
We had a new door ordered when we got it because the original was bowed. Used the original for the shelving - good eye!4ncar said:Shelfboard is near perfect, if not a perfect match! Did you order from nucamp?0 -
400 only, but we had the 320 CS-S and the drawers were awesome for storage!DigitalSorceress said:This is where I as a 320 S owner turn just a teeny bit green with envy.. what is this "closet" of which you speak ..
