I have a 2018 Tab 400 and am installing a Renogy 200w solar suitcase system. I need to mount the Renogy Rover 20A controller. It is 6" w and 8 1/4" h. The manual is recommending 6" of clearance above and below.
Where are others mounting the controller in their 400s? Where does NuCamp mount the controller in the 400 when the factory solar is ordered?
Any pictures of your installation will be greatly appreciated.
Thanks for any feedback!
gande
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
0 ·
2019 T@B 400 Boondock
Could I ask the make and model of the controller you are using? My Renogy Rover seems quite large for either of these installations, especially if I leave the clearance (for cooling?) the manufacturer recommends. Maybe I need a smaller controller.
@grubbster...is yours mounted to the rear of the access door (towards the rear of the trailer)?
2018 T@b 400
https://www.victronenergy.com/upload/documents/Datasheet-SmartSolar-charge-controller-MPPT-75-10,-75-15,-100-15,-100-20,-100-20_48V-EN.pdf
2024 T@g 5-wide Black Canyon
2020 TAB 320S Boondock Lite
TV: 2018 Jeep Grand Cherokee
2018 T@b 400
2020 Toyota Tacoma Double Cab
Amazingly, I wired everything correctly and the Renogy 200w suitcase panels easily kept our battery charged on our latest four day trip to Monterey Bay where no hookups were available in the state park.
2018 T@b 400
2018 T@b 400
