Hi, totally new to the t@b experience having just purchased a t@b 2008 model Q recently...I seem to be totally flummoxed before I can even get out of the driveway...All systems work fine on AC power, but when I disconnect A/C, I have nothing from my DC battery... I have studied fuse placements for my model and have no in-line fuses on the leads from the battery cable whatsoever...I have studied battery on/off switches but this model doesn't seem to have one. I have brought the battery up to total full charge according to my charger....All fuses in the power converter box seem to be fine...I don't have a clue what to check next...Can anyone offer me some advice on what to try next? My understanding of the electrical system is next to nil...Thanks in advance for any ideas...stuck in the driveway in Montana..
0 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Here is some info from the Yahoo TaB group:
What about that little thermal relay just outside the battery box in the front? I have found that it can go bad, lights will come on when connected to power, but not be charging the battery...
Electrical Troubleshooting
https://xa.yimg.com/df/tabtrailers/ElectricalTroubleshooting.pdf?token=I6_RAZz50DNMCr_NRP_siYwiPztDnk_1AAXLIryqSWspSQUf2s5UyxznLrL6sH63I_lMJMWUDOI7-GoZhk_VX2-ykUWYCUeXpbUkEKUdejY0IIHOX4TtyTooB4W_5aXiPMlzApIQ2A&type=download
Fuses in T@B:
OE Fuse
15 amp – Heat Pump
15 amp – Refrig
15 amp – Lights
5 amp – Water Pump
1 amp – LP
Flip Switches:
30 amp – Main
15 amp – Receptacles
20 amp – Heat Pump
Converter
https://xa.yimg.com/df/tabtrailers/WFCOManual.pdf?token=Dgs7hePvTtEt9JvP0L8oopVhQWDoEWxBYEB-VmjmTs04syc3h7JVOjcLrDDBOpVkwVNkjNCr_XZHnQosSJZ4aVDwZnXKIiq3GQRoxoMOld2Nuz-smeBjPA&type=download
