Newbie here! I have already learned a ton just from searching here.
Just purchased a used 2018 T@B 400! First camper for long time tenters!
The inside looks great but I've noticed that the trailer and wheels have some issues. Previous owner took it across country last summer. During the Winter it sat outside in New Hampshire. I towed it home 2.5 hours without any issues.
You can see the rust on the frame which I removed and painted - kind of surprised to see this in a 1 year old trailer!
My next plan was to add some grease to the bearings via the Zerk fitting, but when I looked closely at the wheels I was shocked by the amount of rust on the hubs!! Also, I noticed that a lug nut is cracked.
I assume I'll need to replace the lug nut, but what about the hubs? Can I remove the rust and paint them or should I replace them? Should I plan on checking the brakes as part of this maintenance?
Thanks for your input in advance guys.
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
2022 Ford F350 Tremor | 2022 Cirrus 620
The cracked nut is I belive the stainless decorative skin and not actually the nut, still may want replace it but if I am correct it is only affecting the appearance.
In terms of bearing grease I was planning on just adding a little and not totally replacing as I'm concerned about getting it into the brakes.
There is a video from Dexter on how to use the zerk fitting within this thread. Good read, too.
Dexter has confused the issue because they use the term “repack” when discussing the EZ lube procedure. https://www.dexteraxle.com/resources/videos/bearing-maintenance
Use of the EZ lube system is “repacking” using the zerk fitting instead of disassembling the hub. What is the point of the zerk lubrication system otherwise? I think the real question is, if lubing every year or 12,000 miles as recommended by Dexter,
how do you know when to inspect the bearings? I found an answer on the Forest River forum. Someone suggested that any evidence of lube that appears milky (water infiltration), gray or with particles (metal shavings) indicates a need to pull the hub and inspect the bearings. Also, feeling your hubs at rest breaks while traveling is a good habit.
Also, there has been discussion on this forum of the amount of grease that each hub required the first time they used the zerk system. It is not unusual to require most of a 14 oz grease canister on each hub. I believe @MuttonChops had a good explanation for this in that at production, there was limited grease used to pack the bearings. I also found a report of Dexter axles replaced under warranty due to failure from insufficient grease at manufacture. So, now I think it is a good idea to be proactive and lube via the zerk early on in ownership.
I personally think if you are pulling and inspecting, replacing parts as needed and repacking, then there is no need normally to ever grease using the zerk between full services. I have a Wells Cargo trailer with over 30k miles doing it how I suggest with zero issues, I have never hooked the grease gun up between servicing. FYI, at least once the inner grease seal needed replaced before the 12k limit and prompted an earlier service.
I also belive Dexter has a 6mo interval for brake inspection/adjustment which reinforces the idea of how important it is to look at components.
Having said all that, I may pump grease in my new 400 hubs just to make sure they are full, simply because I am short on time to do a teardown with a trip planned this weekend, but it is only been off dealer lot for two months and components should still be in good condition.
Check 2nd comment By Ripley711 on 8/8/2017. First page.
@N7SHG_Ham - I agree that anyone acquiring a used trailer should do a complete inspection. I just wanted to clarify the terminology in relation to lubricating.
A few other questions:
1. Do I have to worry about grease getting into the brakes using the Zerk fitting?
1. Any info on how to check/service the brakes?
2. Can I use a scissor car jack to lift the 400?
Recent thread on brake adjustment:
http://tab-rv.vanillacommunity.com/discussion/comment/119540#Comment_119540
For the 320s and 400s you want to use a bottle/scissor jack to lift the camper – mounting location right behind the tire where the Axle and Frame meet. You need to make sure to lower the stabilizer jacks on the opposite side and have the trailer connected to your tow vehicle for stability.
Here is one thread on the jack point. Do a search and you will find more.http://tab-rv.vanillacommunity.com/discussion/8159/tab-400-jacking-points
2) See the related thread about adjusting the brakes. If you have done brakes before then you know not to over-loosen and unthread the adjuster. The advice given to adjust and turn until there is a slight drag/rubbing is correct. Check the drum temperature after a few miles of driving and loosen it if it's too hot. If your seals are blown then you need to replace the pads and clean the drums before you reassemble. Drums can be a real PITA so again, having a mechanic get you to a known baseline is a great idea.
3) If you have a floor jack use it instead. Bottle and scissor jacks are not the best option for home shop use. If they are not precisely placed they will shift. Hence the suggestion to jack the T@B while attached to the tv. Scissor jacks will bend and twist. Use them only when you need to, roadside. Regardless of what jack you do use, put your jack stands in place before you start to lift. Adjust the stands up as you go. Break your wheel lugs loose before you start to jack the trailer up. The nuts should be very tight and the tire/wheel will spin without loosening the nut if you have it off the ground even a small amount. Do not remove the lugs before you jack the trailer up, only break them free so that you can remove them once the wheel is up. Once you can freely spin the wheel you have lifted far enough. After making sure the jack stands are secure, remove the wheel. Hopefully you have a torque wrench/breaker bar in your kit so that you can put them back properly.
WRT blowing seals with a grease gun....it can be done even with a hand operated gun. Air is your enemy as is aggressively pumping grease. The key to using the grease gun correctly is to make sure that you use the bleeder on the gun before you start putting grease into the grease fitting. You must always bleed the gun when a new cartridge is installed. Once it is bled, then you should pump grease through the tube until the gun is delivering grease without any air. When the gun is ready attach it to the Zerk fitting and slowly start pumping in grease while turning the wheel to push the grease through the bearing. If the grease looks good and is coming out readily, you may decide to stop and call it a day.
If you plan to replace the grease, a trick some folks use is to use two different color greases so that you can tell when the new grease has replaced the old...the red Lucas or Mobile One grease is often used for that. I keep two grease guns in my shop, one red, one blue....
The key here is to make sure that you use the same grease type...if you mix grease types the carriers will fail and your grease will run out like thick oil.
If you see any signs of metal in the grease after you pull the cap stop and take the trailer to a mechanic. Any metal in the grease suggests either a failed bearing or worse, a damaged spindle. Good luck. It's great to be able to do these tasks yourself.
