Recommended tool and spare parts list?
Runtarooti
Member Posts: 76
I searched for "tool kits" "tool sets" " tools" but did not find a summarized list. I'm new and and looking to put a kit together. I have made a starter list from reading the posts but would appreciate input from the collective experience from the group. I hate those "if I only had a _______ (fill in blank) moments, especially if I'm miles away from the stores
Also, Should tools be SAE or metric or both? (even built in USA can use metric)
Here's some notes I have made so far...
* R1, R2, R3 bits plus phillips, slotted and driver
* breaker bar and 3/4" deep socket plus socket for spare
* blade fuses, glass fuses (see fuse list for newbies)
* duct tape, electrical tape
* cordless drill and socket for raising stabilizers if desired
* multi tester
* spare batteries as needed (AA, AAA, etc)
* flashlight/headlamp
* WD-40
Thanks!
* multi tester
* WD-40
Thanks!
2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback
Mallet
Small claw crowbar
Lithium grease
DD batteries for O2 fan
Gorilla tape
Twist ties (those suckers come in handy more often than you think!)
Small level
Misc wire connectors.
Extra coupler pin
Extra hitch pin
Don't use multitools with tiny bits. T@Bs eat them bits for lunch.
Get real R1,2,3 and phillips and flathead.
Light test light
Bandaids
Extra cords for charging
Pocket knife
Small hatchet with sharpener
Small tube of sunscreen and bugspray (change out every season)
lip balm
WD-40
PS.. I've used every one of these camping!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2 -
I've found these great for mods it repairs. I've attached my Rubbermaid container to the platform with them, and just used one to support my gray water extension.
Serious Ties - Extra Heavy Duty Cable Ties (50, 24 Inch/175Lbs/UV Black) https://www.amazon.com/dp/B00I0F1AH4/ref=cm_sw_r_cp_apa_mGu9ybG6XWV892015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6203 -
Bungee cords
ball bungees
fold-able shovel
matches with water-proof container
long handle lighter- 2 are better
duct tape
superglue
hammer
crescent wrench
fuse tester (some fuse kits at automotive stores have these included)
Small rake
broom2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf2 -
I always bring all of em....
that way I'll never need any of em.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya4 -
Love these lists... The best thing about this forum is 1,000 heads are better than 1
A lot of the above plus:
Silicone spray - great for the hitch latch, ball, and keder rail before feeding in an awning/tarp/tent
Bike cable lock to secure the surge protector at the power post
Brass 'Y' hose connector at the faucet
Leather work gloves
Hand lotion
Hand sanitizer
Scissors
Case cutter
Tape measure
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Double scissors.. make sure they are sharp and don't rely on the ones in your pocket knife!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
I always carried a spare wheel hub on a stub mount on all my boat trailers. Does anyone carry a spare and if so where?2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
Water filter for hose, coaxial cable for tv along with everything else mentioned above. Spare is mounted on tongue jack.0
Channel lock pliers
Side cutters
JB Weld
Torque wrench
Tire valve kit including wrench and valves
Tire plug kit
6 plus feet of wire
Paracord
Latex gloves
Paper towels/rags0
