Hi all,
I'm trying to expand on the 2 USB charging ports on my 320CS. I have 2 ports in the "charging station" and I'd really like to have 4 or 6 total. The first thing I did was buy a splitter. Turns out that while each port can charge a device, doesn't seem to put out enough power to power all 4 ports on the splitter. Thus, the splitter didn't work (and I'm currently hooked up in my driveway, but typically we're boon-docking)
I guess my questions are: 1) can I swap out the "charging station" outlet for something more powerful and 2) I saw some folks removing their interior TV and putting in a nice shelf...would it possible to put USB charging ports over there? AKA, can whatever is powering the TV be converted into USB power?
Thanks
Mike
0 ·
Yes, you can swap out a charge station or add one wherever you have a 12 v source.
Keep in mind, the USB outlets are a source of phantom drain. You may like just plugging in a 12 v USB adapter.
https://www.lifewire.com/finding-the-right-12v-usb-adapter-534755
https://www.etrailer.com/12V-Power-Accessories/Diamond/DG61030VP.html
This is the splitter I am trying to use: https://www.amazon.com/gp/product/B00O0KISQE/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
This is the 12V USB charger I am using: https://www.bestbuy.com/site/platinum-quick-charge-car-charger-black/5713024.p?skuId=5713024
All devices work normally (I tested the splitter with my computer)
Ok here is where I am at:
- Plug phone into stock trailer USB port: phone charges.
- Plug splitter into stock trailer USB port: splitter turns on, but won't charge my phone
- Plug 12V USB charger into trailer: charges phone
- Plug splitter into 12V USB charger: splitter turns on, but won't charge my phone
So I guess the issue is the splitter. I think the next attempt would be a splitter that plugs directly into the 12V as suggested earlier. Maybe something like this: https://www.amazon.com/BESTEK-3-Socket-Cigarette-Lighter-Splitter/dp/B00XP5C3XY/ref=sr_1_4?keywords=12v+usb+splitter&qid=1562589528&s=gateway&sr=8-4Thoughts?
https://www.bluesea.com/products/4364/Water-Resistant_Accessory_Panel_-_15A_Circuit_Breaker_2x_Blank_Apertures
https://www.bluesea.com/products/4367/Water-Resistant_Accessory_Panel_-_15A_Circuit_Breaker_3x_Blank_Apertures
https://www.bluesea.com/products/4369/Water-Resistant_Accessory_Panel_-_15A_Circuit_Breaker_4x_Blank_Apertures
https://www.bluesea.com/products/1016/12_24V_Dual_USB_2.1A_Charger
You will need to use the 12V (cigarette lighter) socket, or hard wire in a USB charging port, similar to what @klenger posted, or something similar to what is already installed.
https://www.bluesea.com/products/4368/Water-Resistant_Accessory_Panel_-_12V_Socket_2x_2.1A_Dual_USB_Chargers_Mini_Voltmeter
For example, I replaced our blown USB ports with a new 12V socket & the following adapter to charge our Samsung Galaxy Note8 phones..
https://www.amazon.com/gp/aw/d/B07H4LH6P7
It specifically lists our almost 2-y/o model in the description and the exact dual voltage/current levels used by the device's fast charging protocol..
Protocols often get updated with newer phones & then new chargers to support them. Read the details to make sure your specific devices are supported if you want fast charging at full power. Voltage/current outputs should be listed on the 120V AC wall charger made for a specific phone, or in its specs.
Here's my install writeup & photos..
https://tabforum.nucamprv.com/#/discussion/8902/rear-usb-ports-dead-replaced
PS: Here's a good article about fast charging & how it's implemented on various types of devices, Apple & Android..
https://www.google.com/amp/s/www.digitaltrends.com/mobile/how-does-fast-charging-work/?amp
(previous 2018, T@B 320 Outback)
