ALERT: 'Rotten egg' smell in trailer [what to do]
b407driver
Member Posts: 139
I'm guessing many of you experienced people around here would be able to guess the source of this, but for those of us new to RVs, thought I'd post this as an important FYI.
If you ever have an odor in your rig that smells like rotten eggs, it is likely the batteries overheating. Your CO2/smoke alarm may go off (mine did). If this should happen, I would suggest you:
This is in regard to 6v AGM batteries in my 2020 T@b400 w/solar (pertains to regular flooded lead-acid, as well), and I'll provide more details as I have them. Hopefully this is a simple one-off from a bad battery cell.
-Jeff
- Immediately shut everything off;
- turn the battery switch off;
- start to ventilate;
- disconnect the batteries and preferably remove them from the trailer; and
- try not to breathe the gases (hydrogen sulfide). <----- [probably should have led with that one, lol]
-Jeff
2020 T@B400 Boondock Lite w/solar
2024 T@g 5-wide Black Canyon
Thank you for this. Hopefully you’ll be able to give us some more details like the ambient and indoor temperature etc. I’m glad they didn’t blow up! And if there are ramifications for your solar and controller, replacement under warranty etc.John, Judi, Guinness & OD in PDX
Whoa! That’s a new one - and an AGM yet!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes it is, sounds like a first for nuCamp.Sharon_is_SAM said:Whoa! That’s a new one - and an AGM yet!
It's been flippin' hot here, 90 outside, probably 106 in the trailer.2020 T@B400 Boondock Lite w/solar
Jeff --Front Range of Colorado0 -
Just thought of this - for those with batteries in the tub, do you think some Reflectix over the tub would help keep the temperature down?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Sharon_is_SAM Do you really think that the temperature in the tub, in full sun is greater than that under the hood of a car stuck in a summer traffic? I really doubt the temperature is an issue for these batteries.2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut2
Actually, I have an thermometer sensor in my front diamond plate tub and in the glove box of my truck. The front tub is much cooler than the inside of my truck, year round.Verna, Columbus, IN
@webers3, so just a bad cell in the battery is enough to cause the overheating?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Sharon_is_SAM - Absolutely. Internal shortage between cells will overheat a battery in no time! AGM's are really no different from flooded lead acid batteries, except they have the fiberglass mat between plates.Jon & Angela | Florissant Colorado | 2017 Outback S0
So as far as ambient temp is concerned, it will only effect battery life duration?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Sharon_is_SAM @webers3 The OP lists a 2020 400 boondock lite as his trailer type. that might reduce the ambient temp issue.2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods0 -
So the battery distributor has said that there is virtually no way this can happen without the battery being overcharged, so now they are looking toward the converter (trailer was mostly plugged into shore power when this started).2020 T@B400 Boondock Lite w/solar
Jeff --Front Range of Colorado1 -
That's certainly a likely possibility, but I wouldn't buy it out of hand without further diagnostics. While it's unusual, batteries can and do fail even when they are brand new.Regardless, if I was the battery distributor I'd blame the charger as well. ;-)2015 T@B Max S (320)
WFCO is really good with their trouble shooting & warranty replacement policy. the unit has a 2 year warranty. Mine went bad(320S), and the replacement was simple, tedious, but simple. I would contact WFCO, they can talk you through the trouble shooting process. It will require a multimeter. In doing this you can assuredly determine if it is the charger or not.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
They want me to bring the trailer to the dealer, but I have to be honest, not sure I'd trust the work they'd do compared to me winging it with a multimeter. Maybe I'll call WFCO.2020 T@B400 Boondock Lite w/solar
Jeff --Front Range of Colorado2 -
New versions of the WFCO converter have an amber LED indicator that is lit in 'bulk charge mode.' If this indicator stays on when you think the batteries should be charged then you definitely have a problem. I don't think that necessarily would isolate a converter/charger or a battery problem but it does indicate some problem.
The first time I saw the picture I knew it had been over charged. See it fairly frequently at work.
A question to the OP do you leave your trailer plugged in all the time? Or was it plugged in for an extended period? Any idea what the voltage was on the charger before you disconnected the battery?
I measured mine and it was 14 volts on a fully charged battery and no load, beyond the parasite drain. Seemed a bit high to me especially since it had been plugged into ac for a couple of days.
I would hope the float voltage would drop to 13.6 and after 2 days it should well be through absorption charge
For “two” batteries to fail at the same time would seem to point to the converter. Scary event for sure and thank God you found it before a fire occurred that would have been devastating. Most people think about the detrimental effects of winter on a battery, but warm temperatures are actually a battery’s worst enemy.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
@Cbusguy, it was plugged in for a couple of days after returning from a trip, as I was in and out, and it was hot and I wanted to be able to vent when I was in it. I don't know what the voltage was, as I was scrambling trying to get the batteries disconnected and removed. I do have the solar controller data (history), but not sure if the relevant info would be included?2020 T@B400 Boondock Lite w/solar
@Michigan_Mike they were both over charged so they would both fail at the same time......from the pic it only looks like one is really swollen2009 GMC Canyon, 3.7 liter
One was definitely worse (the one connected to the neg wire), but the other was also bulging out, and in fact had a couple of small cracks near the negative terminal.2020 T@B400 Boondock Lite w/solar
Sorry, forgot to follow up. Converter was defective and replaced (all of a sudden had started charging batteries at >15v), all is back to normal, batteries were also replaced. Dealer would have replaced batteries with 190aH 'in-house' batteries had I not intervened.2020 T@B400 Boondock Lite w/solar
Jeff --Front Range of Colorado4
