Exterior Lagun Mount
GatorEgg
Member Posts: 482
I'm putting this under Factory Comments but maybe a fellow tabber can answer in. Is it possible to swap the bottom adjuster screw around the opposite direction? It seems pressed in. And no, it won't go in from bottom up. If I could swap it around I could lower the table to a reasonable height without jamming in the fender flair. This is a 2018 Boondock. Thanks.
Odessa, Fl.
Odessa, Fl.
Some one on Facebook modded the table adjusters with wing nuts, eliminating the chunky handle.Not sure if it made it over to the Forums....
Towed by 2014 Touareg TDi1 -
Thanks, this is where I was headed to, but I really hoped not to start removing factory parts on a brand new trailer.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
Michigan Mike did a nice post on the required mod in 2016.
https://tab-rv.vanillacommunity.com/discussion/3608/lagun-table-pedestal-mod-amp-outside-use/p1
This is extracted from Mike’s post:NHCraig Posts: 17MemberThere is a simpler (but more costly fix) that I found. We have the outside mount, but couldn't get the table low enough because as discussed, the tightening mechanism is on the right and bumps into the wheel well trim. Turns out you can buy that vertical support from Lagun with the mechanism on the left. Costs about $100 with shipping, but once you use that as your vertical support (inside and out) you can get the table as low as you'd like. So if you're not lucky enough to have a machinist friend, it's an option.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Well, it looks like nuCamp is paying attention . Our 2019 Lagun table leg has the adjuster screw on the opposite side now (left side, as opposed to the right side on the older ones) . Of coarse you have to make sure where its placed when tightening it up so it doesn't interfere with the cargo door opening now !2023 Ford F150 Sport 3.5 Ecoboost
I called up customer service at lagunusa.com and bought a vertical leg with the handle on the left.John and Henrietta, Late 2016 T@B S Max in Western New York0
I swapped mine. I need to look at what I did(I forget), but it may have been as simple as knocking the threaded fitting out and swapping direction... I’ll check...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0
