All was well with our T@B 320 electrical system last weekend when camping and hooked up to 30 amp outlet. I just plugged it in at home and I have to use a long extension cord from the garage to an adapter to the Progressive surge protector to the 30 amp cord. The surge protector isn't registering any errors. The voltage is reading 119 or 118 (seems like it was higher when I plugged it in before). Now there isn't any power to the fridge, or the outlets (including the outlet the AC is plugged into). The AC fan works, the fantastic fan, works, the lights and radio are OK, the ALDE panel works. Is this just a low voltage problem or have I blown a fuse? I appreciate any help anyone can offer. I did look at the Fuses for Newbies and I figured out what fuses go to what appliances but I was hesitant to start messing with them.
Kathy
2018 T@B 320S - Cl@ra
0 ·
BTW, with long runs of smaller gauge cords (under even a small load) you will notice the cord heats up considerably. That is a consequence of the high resistance.
As @ScottG suggested, first check your breakers in the Tab (the fuses are only for 12V items). Also check the GFCI breaker on the outlet under the bed to be sure it's reset (however, I don't think the fridge is on the GFCI circuit). There's also a special breaker on the plug for the AC.
But because all the 120V outlets seem to be off, I'd suspect the Tab main breaker.
Also, since it sounds like you are plugged in to a 15A circuit at your house, keep in mind that you are going to have less available electrical power than you would otherwise have when plugged in to a 30A circuit. Therefore, be careful not to overload the circuit by having too many electrical devices on at the same time. If you are trying to run too many things at once, you're likely going to trip one or more circuit breakers.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
