Clamshell Galley Wing Walls
I came up with a cobbled together prototype a while ago. An old tarp, some ball bungees and masking tape. I was always planning for a more refined version but........... there is nothing more permanent than a temporary solution.Meme's version looks much nicer in many ways.
Have Fun!1 -
Got our 360CS Galley Wing Walls from Meme, and they’re awesome!
The recommended way to stow them is using command strip “wire bundlers” and roll the wing walls up and hang them on the door (see the video on their site).But the 360CS has those shelves in the spot, and to lash them low enough to not hit the shelves the command strips bundlers would be upside down at some point - and probably come unhooked.
So I designed and 3D printed some strap/anchor guides and bought some silicone straps off Amazon. I attached the anchors using command strips outdoor, to better handle temperature variations and humidity.
The rolled up wing walls hang on the door, just and sit clear of the shelves when the door is closed, and they’re nicely stowed out of the way when we are not using them.
I have the 3M cord bundlers and I like your solution better. I don't suppose you'd be willing to sell me a set?
@Marceline I DM'd you.🙂
