Propane Tank Full - No Gas at Stovetop
Pekoe1111
Member Posts: 54
is there a shutoff valve?
thanks
thanks
There is a safety regulator on the tank. Here is a thread that talks about it.And some ideas on how to "reset."
Towed by 2014 Touareg TDi -
You probably opened the gas tank too quickly. Turn the tank off. Make sure all the gas appliances are off in the trailer and then remove the gas hose from the tank to release the pressure and then reattach it.
Then slowly reopen the valve on the tank. There is a safety feature on the new propane tanks that activates if it doesn't see enough back pressure
There is also a safety feature in the stove that requires you to hold in the valve for a bit till it senses the stove is lit2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
Got it going! Is there a procedure to start the fridge?
what year is your trailer?
Some fridges have a label inside the door with instructions.If not, here is a thread about a stubborn propane fridge and various techniques/instructions.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
