Our last outing was to an area with limited resources so I bit the bullet and purchased the Harbor Freight Predator 2000 generator.
Yes I know there are people who will claim you get what you pay for but after doing exhaustive research and talking to friends that own them, I could not pass up the price of $449.00 VS $1000.00.
What I took away most from my research is that proper break in and maintenance will make or break how long it will last.
First, when you get it home and unpack it, you will need to run it and change the oil several times. Unfortunately, there are metal shaving still in the engine that need to be removed. Scary thought but if you know about it, you can eliminate the problem quickly by breaking in the motor and changing the oil a few times. A few people swear by an oil additive too but if you keep the oil changed frequently, I personally do not see a need.
Second, use premium fuel and a good gas conditioner to keep the gas moisture free. There are dozens to choose from so I chose the Seafoam brand. This was again a personal choice since I have used the product for years.
After the initial start, the generator always started on the first pull. It is quiet enough not to be annoying on the eco mode. I ran it about 2 hours a day to recharge the batteries. As a test, I ran the air conditioner by itself without any issues. Made a cup of coffee with the Kurig. Made some toast with a toaster. Ran the generator about 6 to 8 hours total and did not go through a full tank which holds 1 gallon.
I hope this helps out others who are thinking of investing in a generator.
"Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
3 ·
PNW
https://www.harborfreight.com/3500-Watt-Super-Quiet-Inverter-Generator-63584.html
I did want to mention one of the main reasons that I chose to pay the higher price for the Honda. Because the Honda EU-2000i/EU2200i is THE benchmark for small portable generators, I suspect it is still the single best selling model. Because of that, a company called Orbital Machine Works builds a security product for the EU2200i generator called the LowPro LockDown mount that I installed on the tongue of my T@B 320 to securely carry the generator. The only other brand generators I have seen this product for is the Yamaha generator. I was willing to pay the premium price for the Honda just for the opportunity to pay a premium price for the LowPro LockDown, and I am happy with the decision. Because there are so many knock-offs on the market now, I doubt that you will see products like the LockDown adapted to those models.
For details see http://www.klenger.net/a-frame.html
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
Do you store the generator in the locked box when you’re done camping or would you expect the heat to damage the generator over time?
TV: Toyota 4Runner
I just purchased a 2200i Companion model with propane conversion, will run close to 24 hours at light loads on a 20lb lpg tank.
2018 Tab 400
2019 Tundra CM
Wisconsin
Some Champion units (and maybe others) have a 30a RV receptical.
