Rust on chains - question
I've been in Oceanside, parked at my son's house and while preparing to leave, I noticed rust on the safety chains (my desert mind hasn't had to consider rust before)! It's been about 5 weeks but I'm worried I need to change them immediately. I'm only driving 7 miles today to the campground and will be there 4 nights. Is this something I can do (I haven't looked at where they're attached to the tongue) and how soon should I do it? There isn't a CW near here - where else can I get the chains and what specific "size" am I looking for? Thanks!
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Sounds like it is surface rust and is pretty normal.  Check them ever so often, but you will be fine.
    Sterling, VA
  • Dalehelman
    IMHO surface rust on safety chains would not a problem for years. You could wipe them down with WD40 from time to time.
    1. Hash  T@B Fun
  • Nomad
    Nomad Member Posts: 7,209
    edited November 2016
    Agree with others, surface rust is not a problem.
    I did replace mine awhile back, wanted bigger hooks. Simple to do, two bolts on bottom side of frame. I bought them at a trailer place only because none of the hardware stores had the right length in stock.
  • db_cooper
    db_cooper Member Posts: 749
    I use Boeshield T-9 for everything,  has a wax in it to hold the lubricant in.  Bike chains,  hitch ball,  coupler,  tools,  etc.   It is really a great lubricant.    But agree with others,  no way your chain is compromised in 5 weeks,  even if you left it laying in saltwater.
  • irvingj
    irvingj Member Posts: 335
    Ditto on the surface rust not being a problem. (You should see the safety chains on my 30-year-old boat!)  And another STRONG vote for Boeshield T-9!! Was introduced to that stuff after purchasing a '56 Piper PA-22-150. Boeshield is really awesome; I also use it everywhere!
  • kidware
    kidware Member Posts: 13
    We replaced ours with vinyl coated, coiled cables ... much easier to work with.
    Lou in Seattle
    2012 LG T@B towed with 2004 Suburban
  • ericnliz
    ericnliz Member Posts: 4,437
    kidware, Where did you get the vinyl coiled cables?
  • Verna
    Verna Member Posts: 6,876
    I love mine, @ericnliz . From Amazon, and there are other choices, mostly more expensive. The ones I have are good for 5,000 lbs. My original safety chains were a few inches too short. No problem now.
  • ericnliz
    Verna, thanks. Ours were too long for either [here we go again] of my TV's [not the kind you watch ]. I had to shorten them by about 3". Not hard, two nuts, two washers, and two lock washers.
  • mickietucs
    mickietucs Member Posts: 720
    Thanks all! I'll look for the rust stuff and dry lubricant soon. Tomorrow heading inland (boo-hoo) and back to the desert area soon. See you at T@Bazona in Jan!
  • jkjenn
    jkjenn Member Posts: 6,425
    @Verna I just got those Curt chains delivered today. Will 40" be long enough? They seem short.
  • Verna
    @jkjenn, I no longer have my T@B S Max, but whatever length of coiled cable came with this purchase was sufficient in length.
  • jkjenn
    Thanks, @Verna! I think they will work for me, too. I am just so used to the super long chains that came with the T@b. This is on the weekend to-do list. I have my PB Blaster ready, if needed.
