Rust on chains - question
mickietucs
Member Posts: 720
I've been in Oceanside, parked at my son's house and while preparing to leave, I noticed rust on the safety chains (my desert mind hasn't had to consider rust before)! It's been about 5 weeks but I'm worried I need to change them immediately. I'm only driving 7 miles today to the campground and will be there 4 nights. Is this something I can do (I haven't looked at where they're attached to the tongue) and how soon should I do it? There isn't a CW near here - where else can I get the chains and what specific "size" am I looking for? Thanks!
Sounds like it is surface rust and is pretty normal. Check them ever so often, but you will be fine.
Sterling, VA1 -
IMHO surface rust on safety chains would not a problem for years. You could wipe them down with WD40 from time to time.
- Hash T@B Fun
Agree with others, surface rust is not a problem.
I did replace mine awhile back, wanted bigger hooks. Simple to do, two bolts on bottom side of frame. I bought them at a trailer place only because none of the hardware stores had the right length in stock.0 -
I use Boeshield T-9 for everything, has a wax in it to hold the lubricant in. Bike chains, hitch ball, coupler, tools, etc. It is really a great lubricant. But agree with others, no way your chain is compromised in 5 weeks, even if you left it laying in saltwater.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Ditto on the surface rust not being a problem. (You should see the safety chains on my 30-year-old boat!) And another STRONG vote for Boeshield T-9!! Was introduced to that stuff after purchasing a '56 Piper PA-22-150. Boeshield is really awesome; I also use it everywhere!1
We replaced ours with vinyl coated, coiled cables ... much easier to work with.Lou in Seattle
2012 LG T@B towed with 2004 Suburban1 -
kidware, Where did you get the vinyl coiled cables?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I love mine, @ericnliz . From Amazon, and there are other choices, mostly more expensive. The ones I have are good for 5,000 lbs. My original safety chains were a few inches too short. No problem now.
Verna, thanks. Ours were too long for either [here we go again] of my TV's [not the kind you watch ]. I had to shorten them by about 3". Not hard, two nuts, two washers, and two lock washers.2016 T@B MAX S-aka: WolfT@B
Thanks all! I'll look for the rust stuff and dry lubricant soon. Tomorrow heading inland (boo-hoo) and back to the desert area soon. See you at T@Bazona in Jan!Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you!0 -
Thanks, @Verna! I think they will work for me, too. I am just so used to the super long chains that came with the T@b. This is on the weekend to-do list. I have my PB Blaster ready, if needed.Verna said:@jkjenn, I no longer have my T@B S Max, but whatever length of coiled cable came with this purchase was sufficient in length.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
- 424 Service/Maintenance & Recall Notices
