Wondering if anyone else has had this problem. On our first trip in our 400 I pre-cooled the Norcold by turning it to the 5 setting the night before we left. We loaded the fridge the next morning an took off. When we got to our campsite the fridge had frozen everything solid. My bad, I set it back to the 3 setting and everything was fine. We have had several trips with the camper now and have repeated the set up procedure, turning on the fridge the night before, except now the fridge is not cooling properly. We bought a thermometer and installed it in the fridge. We have trouble maintaining even 47 degrees, on this trip we are up to 50 degrees in the Norcold. 50 degrees is not acceptable. From my reading the fridge should be between 40 and 45 degrees to keep food from spoiling. Has anyone else experienced this issue?
                0 ·
