we just replaced the battery in our CS and I noticed that it did not charge at all during a recent weeklong camping trip at a state park with 30 amp service. When driving home it charged fine. The floor was recently replaced in the camper. Could something have not been hooked up properly? What suggestions do you have to check? Thanks
2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
0 ·
1. Do a visual inspection of the converter. Does everthyibg look like it ought to look?
2. Check your 30 amp battery fuse.
3. Look at the black 12v junction box outside of the camper. It is possible something got knocked, there.
4. Check the water levels in your battery.
5. Check your battery. If you have a DM you should have positive and negative wires going to and from the battery.
Lastly, it could just be bad luck for you and you need a new converter.
Was this the first time connected to shore power since the flooring was replaced? It may well be simply a loose connection or a wire got switched. Show us some converter wire pictures. Also, change out the 30 amp battery charger fuse in your panel and see if that helps.
thanks
carolyn
