I was just curious, how do you maintain good airflow and ventilation and ensure the windows aren't fogging up while camping in the rain?  I'm assuming the main vent fan shouldn't be opened far enough for the fan to be operational during rain so do you just crack it and crack a window slightly?  Can the window over the table and the kitchen window both be cracked when it is raining?
Also, when it comes to the bathroom fan can that be in the open position in the rain?  The bathroom fan is confusing to me because I feel like the molded labeling for the open and closed position are backwards.   When I have it in the closed position it appears to be open and vice versa....
                2020 T@B 400 BDL    2025 Silverado 5.3L V8
Chili, NY
0 ·
@ecstatic No reason not to leave the side and front windows cracked, in all but heavy/sideways rain, they’ll be fine. Just be sure to secure them fully closed again for travel, it’s easy to forget because they may look closed.
When open, it casts a very little bit of shadow on the solar panel at the top, but not enough to hinder it. Could be remedied by parking with the bed window directly facing south.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
If you do not have a rain hood, then the MaxAir, which has the hood built in, might be a less expensive option to upgrading and adding the hood. I already had the hood, so the upgrade was the quick and easy way to go.
Southern California
Full-timer since 2019
I had the TaB 400 Fanstic Fan Model 3350, and to have the remote, additional fan speeds and thermostat, I got the upgrade kit from ETrailer, which basically upgrades the fan to a 7350. All you use from the old fan is the fan motor/blade assembly, clamp frame with the top.
The upgrade involves, removing the inner frame (not the outside clamp frame) which has two models, one with normal corners, and one with notches in the corners, so you need the right kit here. Lowering this frame, pull the manual lower/raise Knob snd lock Knob first, drops the speed switches and reveals the wires. All that is left is the fan motor assembly and the arm that raises and lowers the top, you change this out to with one in the kit. The upgrade gives new co trolls, a motor the the raise/lower arm, which is already wired to the control board which is part of the new frame assembly. The only wires you keep are the hot 12vdc and ground wire to repower the new upgrade, and reattach the fan wires to the new control board.
Try contacting ETrailer customer service at victoriag@etrailer.com .
Also, I have a 4" USB Opolar fan I LOVE and and often have that running for air circulation.
Sold 2023 Tab 400
Sold 2018 T@B 320S
