Hi All - We are new owners of a 2016 T@B CS-S. We bought it privately, but it has never been used so we don't have a dealer relationship. Everything was still wrapped in plastic, not a mark on anything; so we are confident that nothing has ever been used/run. I'm it getting ready for our first voyage and all seems well except the water pump. We finally have a warm enough day to check out the water system without fear of freezing. Hooked up the city water connection and flushed out all of the lines. Everything seems fine. I then filled the on board tank to test out the pump. Tank is filled and the pump runs when turned on, but I get nothing from the faucets - not even a sputter. It obviously isn't priming. Any ideas? Is there a valve somewhere that I am missing? All of the valves in the back under the sink appear to be in the correct position described in the "Winterizing Manual" for "Camping Mode". Is there another valve somewhere (maybe underneath) closer to the tank? I Help. Thanks.
                1 ·
https://www.google.com/search?ei=DkKUWvf5AcSGsQXH5o3QBw&q=priming+pump++site:tab-rv.vanillaforums.com&oq=priming+pump++site:tab-rv.vanillaforums.com&gs_l=psy-ab.3...3356.8538.0.9326.27.19.0.0.0.0.204.1850.15j3j1.19.0....0...1c.1.64.psy-ab..13.0.0....0.b-qhZvgS3C0
After reading through possible solutions to our problem, i filled the water tank, turned the pump on and held the toilet flush down for maybe ten seconds before the water started flowing. Hallelujah!!!
i think completely filling the FW tank helped the head pressure/resistance (minimize the distance from the high water point in the tank to the pump) and flushing the toilet (the lowest fixture) was the cure.
thanks for all the help. Happy Tabbing,
Brett
Look at the categories on the left and choose the discussion that is easiest for you to understand and print it and put it in a folder:
Fuses for Newbies
Winterization procedures for your year and model of T@B (find the discussion that explains it best for you)
How to change a tire (never put the jack under your axle)
Battery maintenance
Refrigerator maintenance
Phone Numbers for the nüCamp factory
The link to this T@B forum ( just in case you use someone else’s computer)
Whatever else you feel is important
1. Have you hooked up to city water and opened all your faucets (sink and outdoor shower if you have one)? When on city water, make sure you open your hot water faucet and fill your Alde fresh tank. You should see some sputtering at the faucets until it is full. Then close your faucets.
2. Unscrew the clear filter cap and clean the filter.
3. Make sure you have tightened all connections and closed the outside shower faucets.
If these don't work try this with a full fresh water tank:
Disconnect the intake side of the pump and place it in a bucket of clean water. Turn on the pump to see if it will take up the water. If it does, then disconnect and try the pump again using your fresh water tank.
We connected city water to flush through and ensure that the Alde tank is full... I believe it should be since the hot water spigot worked on both the sink and the outside shower. (How can we tell if it is filled?). We disconnected the intake. Water bubbled up through the floor connection. We put the hose in a bucket with water. It vibrates from the pump but the filter is not getting water. We did find that one of the washers was stuck in the pump side of the connection. We pried it out and reseated it. Blew air through that house as well as the outtake house. Cleaned the filter... Nothing. I am at a total loss.
"Inspect the rubber diaphragm in the water pump. If the pump turns on but doesn't pump any water, this could be the problem. Remove the three screws that attach the pump casing to the pump head and check for any damage to the rubber diaphragm. If it is damaged, replace it with a new one. If it looks good, clean it with soap and flush the pump head with water to clean out any built up debris before replacing it and tightening the three screws back on."
Also, what if you disconnect the output hose and try siphoning from one higher bucket to the other through the pump connection? Does water flow at all?
A lot more than 3 screws. Can you be more specific?
valve assembly stuck (jump to 1:14):
complete disassembly:
Data sheet: https://gadgetsgo.com/images-manual/Shurflo-4008-101-E65-A65-specs.pdf
Installation manual/troubleshooting: https://gadgetsgo.com/images-manual/Shurflo-12v-pump-4008-101-A65-E65-installation-operation.pdf
https://youtu.be/dqROXlgt-lI
Thanks, Jerry
Thanks, Jerry
And here are a few links I used to help me understand the pump:
Thanks, Jerry
Thanks, Jerry
