Battery Hot and Smells Like Sulfur
Pekoe1111
Member Posts: 54
We went on an overnight in our 320S after charging on shore power. Our battery didn’t last through the night before our CO detector started beeping. Upon arriving home I hooked it up to shore power overnight and in the morning smelled sulfur near the camper. The battery was the culprit and was hot to the touch. After it cooled down, I check the water in it and one side is bone dry, and the other the water is fine.
should I just add water and hook back up to shore power and hope for the best?
NO!
Towed by 2014 Touareg TDi -
Thanks! Removed it immediately.
Sorry, didn;t mean to yell! In that thread from these forums, there was no follow up to determine if the converter was at fault or the batteries just failed.
Its toast.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
I am with 4n, you may be able to recover it a little bit, but I would never trust it.2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
Sorry, it was a bad converter, replaced under warranty, as well as the batteries, which were obviously fried.pthomas745 said:Sorry, didn;t mean to yell! In that thread from these forums, there was no follow up to determine if the converter was at fault or the batteries just failed.2020 T@B400 Boondock Lite w/solar
2024 T@g 5-wide Black Canyon
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
