In the 400, there are the following notations on the battery monitor panel located just inside the trailer door: 4 lights = "C", 3 lights = "G", 2 lights = "F", and 1 light = "L". Dealer says fully charged AGM battery is 13.4 volts and to never let it get below 11 volts. Has anyone correlated the monitor panel lights to specific battery voltages? [edited to change references to volts]
0 ·
Alan & Patty
Southern Az
No, I want to know what the lights mean - in the simplest terms, is it okay for the state of charge of the AGM battery to get down to one light ("L") before charging it?
We don't know @SAM - that's why the question above - monitor is 4 lights, labeled "C", "G", "F" and "L" from highest (4 lights) to lowest (1 light). No explanation that I could find in the manuals provided with the tab regarding what the lights mean, and dealer could not tell me. Not sure what purpose the monitor panel serves as it relates to the battery if we can't find out what it indicates.
C - Charged
G - Good
F - Fair
L - Low
So far we do not know how any of that relates to voltage or depth of discharge.
in a 400 with the solar package the solar controller monitors the voltage and is bluetooth capable. Although it is located under the bed the smartphone app is easy to use. For more information on that here's a link to a relevant forum discussion:
http://tabforum.nucamprv.com/#/discussion/comment/78113
If your unit did not come with the solar package, Michigan Mike's suggestion of a voltmeter that plugs into the 12V (round) receptacle to the left of the kitchen window is the simplest solution.
Hope this helps. If we learn more, we'll certainly share.
Happy Trails!
Steve & Karen
As others have noted your best approach is to use a true voltage meter. That could be the '12v lighter' outlet and a multimeter solution like the INNOVA 3721 Battery and Charging System Monitor or a fancy 'dash mounted' display panel. Both types have manufacturers providing products over a wide purchase price range.
As for the TAB Panel Battery Light vs Battery Voltage.
Disclaimer: The following is speculation on my part. I have no direct knowledge of the TAB installed monitor panel.
TAB Panel operates like and appears to be similar to a standard KIB Electronics Monitor Panel. Perhaps it is a TAB branded variation of the KIB M21VW Micro Monitor System found at RV & Marine supply stores.Some years ago I installed a KIB M21VW on my boat and obtained the installation & troubleshooting manual. Standard Battery Voltage levels across a number of Micro Monitor models are in the manual and are as follows:
Note: To measure the voltage the Micro Monitor compares a reference voltage to the battery voltage. The circuit to generate the reference voltage (per the manual) is stable between 9 and 35 volts. A battery voltage below 9V will cause the reference voltage to be unstable. Would think that 'low light' could be anything below 9V.
The table suggests you need to recharge when the 'Fair light' turns on. Waiting for the 'Low light' will place the battery well below recommended discharge levels.
@AMac, have you collected some info yet?
My T@B 400 has been sitting in the driveway without being connected to electricity, and I have been relying on my solar controller to give me my battery status.
WOW! The battery voltage has not been under 13.0V, is recharged to full daily by the solar panel that are pointing north, even though I have the Fantastic Fan on medium, and the fridge is on. Because I Boondock so much, I need to know exactly what the voltage is.
So, if you need to know more than 1/3, etc., you will need to purchase one of the above mentioned battery meters to tell you exactly how many volts you have left in your battery to use.
Stupid dealership let my battery die while they had it for warranty work because no one bothered to turn it off. They insist it's fine to let that happen, but I don't think it is.
https://youtu.be/Bq_eDTSzRsE
If you did upgrade to LiFePo4, then they take a charge much faster and because of built in BMS hard to damage. I would be suspect of the four idiot light system with upgraded batteries as LiFePo4 has flat voltage almost to depletion meaning a standard voltage system like the built in one can't correctly monitor charge state.
I would also pick up a good smart charger (Deltran, Creek) and isolate and charge your battery the next time you get to a shore power site. The converter will charge it, but it takes a long time.
