Roof Vent Cover Won't Stay Closed, anyone else having issues?
BigGrover
Member Posts: 450
On the 2019 400 BDL we have Nucamp installed a 3 speed vent fan that has no latch for the cove. Our 2018 had a knob operated hook latch but this one does not. No matter how tight I crank it down it will blow open if there is a 20 mph breeze coming from the side or back. It also blows opens while we are driving. Every time we stop I have to go in and close it. Anyone else having this issue?
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
I have not noticed a problem--yet. I would be very interested in your resolution.
I've emailed Nucamp. Will share what they tell me.BigGrover
Central Alabama -
You mean the roof fan? Which fan do you have? Mine has a latch.
Yes, the roof fan, mine does not have a latch. The one on my 2018 had a latch. Looks like they downgraded from the good Fantastic fan to a cheaper model without a latch.BigGrover
Central Alabama -
Mine does not have a latch. At least that I have discovered. Where is the latch? However, when I crank the lid closed it seems to seal pretty tight.
Interesting; my 2020 does have the latch. Maybe they had a supply chain issue for a while and you got an alternative?
My 2019 built in February 2019 has the latch.2019 T@B 400 Boondock Lite
My 2019 fid too but here's what's in my 2020
BigGrover
Central Alabama -
My 2020 400 BDL has a lock, and a fuse in addition to the open/close, in/out, and speed controls.2020 T@B 400 BDL 2025 Silverado 5.3L V8
Chili, NY -
Hmm... only three models shown on Dometic's site.
It appears they nixed the latch on the latest 3 speed model and added tabs for their own vent cover.
https://www.dometic.com/en-us/us/products/climate/ventilation-solutions/rv-roof-vents/dometic-fan-tastic-roof-vent-_-186152
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
If that's the case, if I have the tabs I better order their vent cover!BigGrover
Central Alabama -
@BigGrover, if you do have the tabs and want to purchase the after-market external Dometic Ultra Breeze cover, you might want to take a look at this thread - - in particular, the info I posted on July 31st. (Greg)
https://tab-rv.vanillacommunity.com/discussion/8414/plastic-brackets-on-fantastic-fan-vent-lid-ultra-breeze-u1400-cover-installation-title-edited#latest
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
@Bayliss thanks much, I will be ok with the smoke colored one if my fan has the correct tabs for the 1400. I just need to find a tall skinny guy who can reach across to push in the rivets!BigGrover
Central Alabama
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
