Alde On button works but the Menu Button does not. Is this a problem with the button itself? From Standby I can touch the screen to get the display to light but no menu. I have the last heat setting used. Nothing else. Any ideas? Y'all are great!
STANDBY MODE / AFTER TOUCHING SCREEN
Are you getting heat?
The manual says this in regards to resetting some of the faults that appear on the display, but you don't even have an error message. I might try it anyway.
"To reset some of the faults and reboot, close the furnace from the control panel and disconnect the 120V to the vehicle and disconnect 12V from the furnace."
So turn off the Display, turn off all appliances, then unplug from shorepower, then turn your battery disconnect switch to off, then pull the 2 Alde fuses under the black cover, then disconnect the 12v wire. Then after a few minutes, reinstall the fuses, then reconnect the 12v wire. Then turn on your battery cut off switch. Check to see if your display works. If not, turn it off and you can return to shorepower.
Just make sure that you get in the habit of turning everything off before disconnecting from shorepower. If not, if the Alde is on when you disconnect shorepower, when you reconnect, you may get a surge of power that can blow the Alde fuses.
Assuming that you have already done as suggested by @nhmike (i.e., press the "MENU" button), have you tried pulling the Alde display panel from the wall to check for a loose wire? That's where I would look, especially since one button works and the other does not. I wish I had taken a closeup photo of the back side and wiring of that panel when I removed it once. Maybe someone else reading this has a good photo they can post. (My 320S is currently in storage.) Below is a factory photo that shows the display panel hanging from the wall, but even after blowing it up, I cannot tell for sure how the wiring is connected to the back of the panel (i.e., whether it is a plug-in type connection, or the wires are connected to a terminal with a screw), but my recollection is that there is a single plastic plug-in connector.
It is also possible that there is a loose connection (in the wiring from the wall display panel) at the Alde boiler itself (located under the driver's side bench) - - I believe that the wiring is under the black cover located on the top of the boiler. Sometimes, just jiggling or pushing in and properly seating wire connections that may have become dislodged will solve electrical problems like this.
If you are comfortable with removing the wall display panel or checking the wire connections at the Alde itself, you should first disconnect the 12V battery connection and 110 AC connection so you do not accidentally blow a fuse. As I recall, the display panel is very easy to remove. The outside cover pops off and there are a few screws behind that securing the display panel to the wall. It's worth a try. (Greg)
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I currently have it set to 62degF and running in my driveway to build some confidence before our trip this week. So far so good. I'll see how it does in actual use on the road. I ordered a 10 pack of the Alde fuses and I'm going to pack my multi-meter!
