Need help with outdoor shower
In 3 years of ownership, I've never used the outdoor shower.  However, I recently had to replace the valve assembly and noticed water shooting out of this hole when the shower handle was turned off, but with the hot and cold water valves turned on.  Is this normal?
  • Tabaz Tabaz Member Posts: 2,411
    Based on the lack of response to my question, I assume no one else on the forum uses their outdoor shower. And here I thought I was the only member of the T&B Unwashed Masses.
    I have used mine. I only see water come out of that hole a few times, but not in any copious amounts. I suspect it’s some sort of bleeder valve outlet, but can’t swear to it...
    I'm ignorant - no outdoor shower - but often unwashed as well.
    On the indoor shower, there's a 'drain back' hole at the base of the hose. Maybe this is the same thing?
    Thanks guys - it’s probably some sort of pressure release device. Chan, you really should shower more. 😂
  • BaylissBayliss Member Posts: 1,483
    edited November 2019
    @Tabaz, I have never noticed mine leaking, BUT until you pointed it out, I never even noticed it.  However, the outside shower is a "Fontana," made by ITC Inc., so I did a search to see if I could figure out what the purpose is.  I found the part, but I am not sure what the purpose is.  Speculating only, I am guessing it is some sort of pressure relief tube/drain for the mixing (hot and cold water) valve.
    Here's a link to the part in question......there is also a diagram showing where the part fits at the back of the shower:
    https://www.itc-rv.com/product/exterior-shower-replacement-straight-nipple-seal-collar-o-ring-assembly/
    Here's a photo of what the backside of the shower control looks like.  The part in question fits in the center of the backside of the control and apparently creates a seal:
    You may want to search for the manufacturer's contact number and give them a call to find out why it is leaking.  I will be following this to see what you find out.  Good luck!
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,350
    In this thread from a few years ago, there is a discussion of a "mixing valve", separate from the main mixing valve in the trailer, in the housing behind the hot/cold handles.
    You can find the comment from "Mr and Mrs Gnome" on page 2 of the thread.  I found the stuff that Bayliss found, and it appears to be a really simple box, but there does not seem to be any information about the operation of the shower at all.
    Thanks everyone for your help!  Because there is VERY little pressure at the shower wand and I never use the thing, I've decided to cap off the hot and cold water lines in front of the valves.  That should stop the small leak from that opening.
    But, @Tabaz , how will you give Sunny Day a bath if she visit you?
    Sunny Day will get to use the indoor shower where the cabin is temperature controlled!
  • rh5555rh5555 Member Posts: 526
    I seem to remember that on my old Coleman pop-up trailer, the outdoor shower had an "automatic" bleed valve which admitted air to allow the shower head to drain when the water was turned off.  Maybe you have a broken one of those?
    I can no longer trust this thing not to leak, so capped off the water lines and put the shower valve assembly into a Ziplock bag for the next owner. Will sleep well tonight knowing this gremlin has been emaciated.
  • DaveAnnaDaveAnna Member Posts: 64
    Here’s the leak issue coming out the “hole”. The connection to the shower hose has a large “nut” in the plastic housing. Remove the nut and the assembly will come out. It’s part of the large round piece. Once the nut and round piece is out, an o ring is around the round piece and a flat washer is between the housing and round piece. Replace the flat gasket, hose washer will work. Re assemble and the “hole” won’t leak. You might be able to just tighten the large “nut” and it’ll stop leaking
  • mlk51mlk51 Member Posts: 12
    Tabaz, What size/type caps did you use to cap off the shower lines? I have no intention of using the outside shower and want to cap off those lines to forestall any leak problems.
    Mary Lou, Grand Rapids MI / 2017 T@B 320-S / 2015 Chevy Equinox w/ trailer package
  • AnOldURAnOldUR Member Posts: 1,632
    @mlk51 You do realize that the outdoor shower connection has many uses besides showering?
  • BinghiBinghi Member Posts: 383
    Yeah, like washing your dog. Got to keep Fido looking good on the road!
    Not for me. I've had outdoor showers in two previous RVs and never used them.
