If you are out T@BBing and the outdoor temperature drops suddenly below freezing and you are not winterized, what are you going to do?
If you had this with you:
Connect up to the spare tire.
Hook up the blowout plug to the city water connection.
Then pressurize and shut off the system at the blowout valve at the spare tire, each time for each sink, and shower, and outdoor shower valve, and the toilette valve, until no more water comes out of any valve. Don't forget, this is only a puff of air each time a valve is opened and closed. In other words, you don't want to run the air out of the tire continuously or you'd flat the spare tire.
Follow published winterization instructions!
FYI the spare tire pressure should be below the water system Max. 50 PSI.
Don't forget to air up the spare after the adventure.
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
It would require a lot of strokes and multiple blow out sessions, but this method also works with a bicycle foot pump.
We have a small 12 volt inflator for winterizing that fits under the passenger seat in the TV; also used to top off all 6 tires before/during a trip.
@tybladesmith's gadget looks like the quick and easy way to go, especially if your spare is mounted on the tongue.
