Heavy Duty Pitched Axle?
xdr
Member Posts: 289
Comes with the Boondocks lite package for the Tab 400. Can someone explain what this is? Ive searched, but nothing comes explaining the details of it.
thanks!
thanks!
2021 2024 T@b 400 Black Canyon, 2020 Ram Rebel 1500
This link (and other links in the thread) discusses what the "pitched axle" is on the Outback/Boondock editions. The bottom line is: about three extra inches of ground clearance.Here is another thread that specifically mentions the 400: warning:techy details!Here is a video of what the axle looks like:And a bunch of threads if you really enjoy the subject:
Towed by 2014 Touareg TDi -
It is an off the shelf Dexter axle AFAIK. Dexter makes axles where you can get a lift or drop, they change the angle in the way the "lever arms" mount to the axle to create the different heights.Start angles available: 45° down, 32° down, 22.5°down, 10° down, 0°, 10° up, and 22.5° up2019 T@B 400 Boondock Lite
Thanks all...so it seems there is a tangible difference between the standard 400 and the boondock model height-wise/road clearance.2021 2024 T@b 400 Black Canyon, 2020 Ram Rebel 1500
One man, one woman, two small dogs and a sense of humor. -
@xdr I think about 3" higher? The axle adds some height and the bigger tires add the rest. Besides the height, BDL adds a few other things, aluminum tub, new models now also have the aluminum platform (was NOT available pre 2020), different entry grab handle, graphics. I think that is about it.2019 T@B 400 Boondock Lite
We have the 2018 400 and the axle is 3500lbs. Nu Camp told me, they changed to a 3900lb or 4000lb about a year later. Doing some checking with Dexter supplier and was told the 4000lb is a 6 bolt hub. Can any one check this and is it also a 6 bolt on the 3900lb or can we use our standard wheels and tires from our 2018? I think the 4000lb is on the boondock and the 3900 is for the regular 400. I understand the boondock uses different tires, wider but still a 15 inch rim. Thanks!
2018 T@B 400, 2017 Nissan Titan Crew cab -
Five lug wheels on my 2019 400 BDL. AFAIK there are no six lug hubs/wheels used on NuCamp trailers although could be on the Avia? Your current wheels should work on the BDL axle.2019 T@B 400 Boondock Lite
Thanks for checking your 2019 BDL. I wonder if the 2020's BDL have the 6 bolt. I saw a picture of the optional black wheel in the flyer and it looks as though it may be 6 bolt. Waiting on my info from my Dexter dealer. Would like to go with the 4000lb but the 3900 would work. Just don't need the extra 3 inches of height. I am working with a 9 ft door in our shop!
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
https://www.youtube.com/watch?v=MzDW1OUbmHc
