Why no auto ignition on stove?
Was looking to possibly replace the stock Dometic stove with one that has an auto ignition feature. From all the photos of 2020 NuCamp models, none appear to have this.  Any ideas why this is? Any other brands available with this option?
    My guess is cost savings.  If they are anything like a grill, over time, they break.
  • Verna
    Verna Member Posts: 6,876
    @Tabaz , if you remember Chuck and Carol at Why in their small fiberglass camper, they purchased two of the stoves like ours with the auto ignition at Quartsite. The auto ignition went out on one of them within weeks. I can purchase a lot of Bic lighters for the cost of a new stove😉
  • JanandDave
    JanandDave Member Posts: 119
    edited December 2019
    Hi. Here is a link to the Dometic site. If you scroll down, you will see Model CE99 which looks like the one in our 2016 T@b and it says it has electronic ignition.
    2016 T@B 320 Max S  "T@BsentMinded"
    2009 Subaru Outback R 3.0
    2022 Ford Ranger XLT Super Cab
  • Tabaz
    Tabaz Member Posts: 2,420
    I tried buying the CE99, but could not find a retailer in the US. I really like the Dometic sink/stove combo with two glass tops. Could not find that unit available in the US.
    pthomas745 Administrator, Moderator Posts: 4,605
  • Tabaz
    Pthomas - you simply don’t understand the level of my sloth, laziness and, well, more sloth and laziness (too lazy to find another synonym). 😴
  • Tabaz
    Verna - did your new 400 come with the auto ignition feature?
  • Verna
    Frank, no, it did not.
  • DenisP
    DenisP Member Posts: 542
    This is what we use.  It is rugged, compact and has worked well for many nights camping.  Cliplight Spark-Key Torch Ignitor https://www.amazon.com/dp/B000NOXDTS/ref=cm_sw_r_cp_tai_yCo7Db2Y514B2
    2013 Tundra TRD 5.7L
    Massachusetts
  • Tabaz
    Thanks DenisP - will order one today!
  • ChrisK
    ChrisK Member Posts: 280
    Wait. You don't cook.
    2014 T@b S Max AKA T@dpole
  • Tabaz
    You're right - I don't cook.  But I do boil water for coffee each morning.  :D
  • Michigan_Mike
    The boys and their tots!  🤣
  • ChrisK
    Oh. That.
  • DougH
    DougH Member Posts: 1,110
    ChrisK said:
    Oh. That.
    Just the most important part of camping.   :)
  • Tabaz
    Just tried out my new spark device. Sending it back. Takes five to six presses of the button before it ignites the flame. Plus your hand is closer to the flame than with a butane lighter.
  • rfuss928
    rfuss928 Member Posts: 1,181
    The arc lighter that pthomas745 recommends above worked well for us all last season.  Easy to use, nice reach, continuous arc and it worked all season on the original charge.  It's the best solution for the stove lighter we have had yet.
    Lighter Tacklife Electric Arc Lighter 2600mAh-18650 Lithium-ion Battery 1000 Times per Full Charge 360 Long Flexible Neck USB Rechargeable Candle Lighter Windproof for CandlesBBQ Fireworks
  • Michigan_Mike
    Oh no, I asked Santa for one!!!!  😲 🎅🏻
  • Tabaz
    I just noticed a hairline crack in the porcelain that surrounds the metal ignitor on the Spark Key.  Will ask for a replacement and also order the Tack Life above.  May keep the Spark Key as a back-up because it doesn't require fluid or battery recharges.  Having your hand "close" to the flame is not a problem IF the Spark Key ignites on the first attempt.  However,  the longer it takes, the more propane is released and WHOOSH when it is finally ignited.
    We use the TackLife, too.  Works well!
  • tybladesmith
    tybladesmith Member Posts: 180
    We use the TackLife and it also works well enough for lighting paper kindling for a camp fire! Charge it once for the season.
  • Verna
    By the way, if you are using the TackLife, it evidently emits a high frequency noise when the button is pressed that is heard by my dogs. Both of my dogs cannot leave the room quickly enough when I use it to light a candle.
  • ChanW
    ChanW Member Posts: 3,165
    Huh! I guess there's a benefit to my old pooch's deafness! (and mine)!
    I've often wondered if the frequencies of my wifi wireless router drives my dog bonkers.
  • Denny16
    Denny16 Member Posts: 5,430
    edited February 2020
    The new 2020 TaB will have a new stove with an electronic igniter.  That said, the one on my home stove went out after 1-year.  We replaced it with a TacLife igniter, after two years of daily use, going strong.  We got a second one for our TaB400.  These igniters work quite well, and come in two different lengths.
  • Tabaz
    I bought the VERY compact TackLife igniter and have been using it for about a month.  The BEST igniter I've ever used.  No liquid butane or batteries to worry about.  Gets the stove lit on the first try each and every time.  This is the model without the goose neck.
  • Cherokee
    Cherokee Member Posts: 346
    check out the 2021 - guess what they've  changed
    California, USA
