I agree with @N7SHG_Ham. The system is not under pressure so the only concern with overfilling would be an increased risk of spillage. Even at the proper level, that tends to happen when you go bumping down the road.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
My glycol tank level goes up when it gets hot. Normal. So if overfilled sufficiently, then run for a while, some could leak and some could go out overflow tube.
2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX Former steward of a 2017 T@B S Max
When you say "by about an inch" do you mean an inch over the proper fill level (about 1/2' above the min mark) or an inch above the max mark? The glycol will expand (and you will see some turbulence in the top of the tank) when it heats up. If you have not left enough room for that expansion the excess glycol will leave the system through the overflow tube. Eventually you will end up with the proper glycol level--and a mess under the trailer maybe.
aka BirdieJane towed by Quinn
Madison, Wi
