Window Corner Protective Stickers
SeaLaVie
Member Posts: 47
Has anyone found a better solution to protect their T@B exterior where the window corners rub? The stuff nuCamp used has worn through.
2018 T@B 400
3M Scotchgard Clear Paint Protection is the product which I used to replace a section which was dirty and pealing on my 400’s front window.
2013 Tundra TRD 5.7L
Massachusetts -
That 3M product is also good for protecting the rear trim piece at the white handle when using the Pahaque visor or awning.2016 Outback 320
I don't think my 2015 320 has any of that stuff--or at least I've never noticed it. I haven't noticed any windows rubbing, either, so I guess all is good.
@SeaLaVie, Congratulations on your Tab 400. I read your posting that you were heading to Tallahassee to take a look at it.You must have bought it then. Happy camping. Enjoy your Tab 400. We are from Jacksonville, FL. That same material is peeling off from my Tab, but I have not fixed it yet.Manny & Anne, from northeast Florida, 2018 Tab 400, Silver with black trim, towed by 2017 Ram 1500
Same issue with mine - will have to check out the 3M paint protection film.Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
DittoScottG said:I don't think my 2015 320 has any of that stuff--or at least I've never noticed it. I haven't noticed any windows rubbing, either, so I guess all is good.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
My brand new T@B400 had that issue right from the dealer inventory. Any suggestions on how to get the old sticker off? Do they peel easily?2019 T@B400
Southern California
Full-timer since 2019 -
I have never tried to remove one of the window rub strips but I have had success removing other glue-on labels and stickers using a heat gun. Put it on a low setting to start and work up. If your heat gun is not variable temperature hold it away from the wall at first and move in if necessary. The idea is NOT to curl the label off but to just soften the adhesive so the sticker will peel away. If there is any glue residue left after the sticker is off use Goo-Gone to clean that followed by soap and water.
Thanks, only one night in it so far but making plans for some January stays...Tabmann400 said:@SeaLaVie, Congratulations on your Tab 400. I read your posting that you were heading to Tallahassee to take a look at it.You must have bought it then. Happy camping. Enjoy your Tab 400. We are from Jacksonville, FL. That same material is peeling off from my Tab, but I have not fixed it yet.2018 T@B 400 -
Our 2015 also doesn't have any protection on the window corners, but there also hasn't been any rubbing marks left.
If it did, i would use this stuff:I use it on lots of things, like bicycles (downtubes, cable rubbing spots, etc), or anything I want to protect but not see. Good stuff to have around. It sticks well, but is usually easy to remove without a heat gun, and hasn't damaged paint when removed.We bought my wife's mountain bike from a bike training class after the season was over for them, and they had covered the entire carbon frame in this stuff. Not a mark on the bike after 20+ training classes where you learn to hop rocks, logs, and small drops.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
- 919 Introductions
- 74 Teardrop Groups & Links
