Hello everyone - my first posting here:
We have a 2006 Dutchman (Thor) clamshell T@B. We took it to Emporia, KS this past weekend with good results, even in heavy rain. Saturday night I found myself wanting some entertainment since the local radio stations are primarily C&W which does not appeal to us. (Remembered later, that I wired the Jensen radio for an auxiliary input of my I-Pod.) So today, while cleaning the T@B I attached the I-Pod to the Jensen and it worked fine, however, it drains the I-Pod battery fairly fast.
So, I think I need to add more convenient 110 or 12V outlets in the cabin for recharging purposes, maybe even a dedicated USB outlet station.
Has anyone done this or attempted this? If so, would like to hear about your experience and any tips, tricks, or traps you may share.
Also, I'm into cast iron cooking utensils, especially using the vintage iron such as Wagner or Griswald when I can find them. We have had fun sharing cobbler cooked in the dutch oven with the KOA hosts in Cripple Creek, CO several years ago.
As a side note, we too have had the hatch leak problem and ruined counter tops. I did a complete gut of the galley this July and August and replaced the counter tops and the side material with matching formica. Also had to replace the floor under the cabinets. Did not have to replace the cabinets. Glad to report the leak is no longer!!!!
John
John & Cheryl
2018 Chevy Colorado V-6
Edmond, OK
0 ·
Will do. Thanks for the info.
Edmond, OK
I replaced the outlet over the stove with one that has two AC plugs and two USB ports (got the outlet at Lowe's) and added a shelf from IKEA to hold stuff.
2012 LG T@B towed with 2004 Suburban
If I were to do it over now, I would run a piece of electrical wire from the outlet under the bench seat, through the coolcat cabinet into the closet and add another outlet.
I did run power to under my kitchen sink by tapping into the outlet under the bench, then drilling a hole through the back wall, then installing an outlet under the sink. I use that outlet for my instant hot water.
Edited to add, I DO NOT USE all of those outlets from the two power strips at the same time. I would have just plugged in the heavy extension cord to the outlet, BUT hubby's CPAP and the extension cord could not plug into the outlet under the bench at the same time, so that's why the power strip. For the plugs in the closet power strip, the only thing plugged in there is the television and a couple of phone chargers.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Thanks for the ideas. Checked the box under the driver side bench seat and was able to route a wire from it over the top of the cool-cat into the closet and then thru an existing hole into the little compartment in the front between the closet and the middle storage compartment. I already have my master 12v cutoff switch installed in that space close to the floor, so I will place the additional 110v outlet and a 4-usb outlet toward the top of that space - should be easy to access. (All connected to the original GFCI.)
Watch out for the metal screen at the top of the cool-cat - it has some VERY sharp edges - ask me how I know!
Thanks again,
John
Edmond, OK
Edmond, OK
http://www.tab-rv.com/forum#/discussion/3011/more-power
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
I've wanted to put a 110Vac outlet outdoors too, but haven't been able to locate a receptacle cover that would handle the wind and rain.
Anyone know of one?
2019 320 Boondock Edge - Sold Jan 2022
I did find lots of residential models, but wasn't sure how well they'd handle rain at 60mph. I thought there might be something that was designed for it in the marine or RV world.
TV: 2017 Toyota Highlander
Not sure if that applies to all of them, but you'd want to confirm that, for battery conservation. Or maybe put a switch in line.
