I am curious if a trailer brake connection and a sway bar is a recommendation, a must, or not necessary in the towing equation? I am about to purchase a 2020 T@b 400 and the dealer says its a must and has added it to my quote/deal. My tow vehicle is a newer F150 with an eco boost engine. rated towing is 8000 lbs. Its an extra $400 to add the electric brake to my truck and the sway bar. Just curious on others opinions on this matter? Thanks
0 ·
Odessa, Fl.
We've never had any sway problem (well, except when my DW first got behind the wheel and got going 75 or so...)
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
2025 Silverado (EV) or 2019 Colorado (ICE)
2018 T@B 320 Sold
Racing the Wind and Chasing the Sun
Virginia Beach, VA
Hence I'm thinking the Anderson WDH w/Anti-sway cone can be an asset. However, I have a secondary question/concern regarding any brand of WDH. It's regarding tow vehicles equipped with electronic stability control [our Ridgeline has VSA [Vehicle Stability Control]; some people say the electronic stability control and the WDH can counter each other in a negative way and create control problems. There are others who claim that the two together are not a problem at all. Does anyone out there have any experiences that could confirm either claim?
Poughquag, NY
I'd highly recommend try towing with out sway bars and decide for yourself if they are needed. The 2021 400 is very stable when towed, but I can't speak to different years with different tongue weights.
@tphaggerty - If you ever get the chance to try it out, the 2020+ Ridgeline has the German built ZF 9 speed transmission with paddle shifters, which has proven to be a nice setup for towing the T@B.
Poughquag, NY
